Question about Cameras
Broken lens mount
Where can I get a replacement plastic lens mount from an 18-55mm lens off a D40x. I dont know how it snapped? I treat it like a baby. useless without repair. very frustrated nikon made this with a plastic mount, all my other lenses have metal
  • 1 more comment
  • Anonymous Nov 15, 2008
    Same exact problem, but haven't had any luck tracking down a solution, other than buying a whole new lens. Ugh.
  • ancmowat Dec 21, 2008
    I have a  plastic mount 55-200 USM canon lens - same issue. Is it a ditch job, or are there replaceable mounts?
  • care7124 Apr 26, 2009
    Just bought a replacement lens mount for my nikkor lens from thefotogeeks.com, and am currently in the process of trying to replace it. I will update as to whether I ever get the old one unscrewed. The plastic mounts are very annoying.
I did get the part in from fotogeeks and all you need are tiny screwdrivers (I mean tiny) and a very steady hand. It took me less than one hour to replace the mount and my lens works perfectly. I am very glad I went ahead and tried to fix the problem rather than buying a new lens. The part cost me around $20. As you are taking the lens mount off make sure you are memorizing how everything goes back together. Maybe even grab another camera and take pics of the process. I did not do that, but had I, it might have taken me less time to get it all together again. Anyway, just wanted to share my success and suggest to others that it is not impossible for a DIYer to fix.
Posted on Nov 12, 2009
The lens wont dtay on Nikon d40x
The bayonet on the lens is probably broken - replace the lens mount, you can find them on Ebay and instruction videos on YouTube
Mar 29, 2012 | Nikon D40x Digital Camera
.i accidentally dropped my nikon
The most recent estimate I received for replacing a lens mount on a Nikon lens was 55 USD. If you want to do the replacement yourself, you can order the part from
http://uscamera.com/jaa79351-f.htm
or
http://uscamera.com/jaa79851-b37.htm
depending on which 55-200mm lens you have.
Jul 28, 2011 | Cameras
Nikon D40 Not focusing, then not shooting
What lens do you have mounted?
The kit lens is generaly made from plastic, and if dropped or hit, the focusing part may break. Therefore it's a lens problem. You need to get it to a specialist to fix it. I own a D40 with kit lens for 2 years now and did not have such problems with it.
Apr 06, 2010 | Nikon D40x Digital Camera
My Nikon DX AF-S Nikkor 18-55 3.5-5.6G ED has a broken mount ring. Can I get a replacment mount? if so, from where?
You can get the part directly from Nikon, and the repair is fairly simple. Look at the step-by-step of the same repair done on this page:
http://www.gmtruckhq.com/artwork-design-forum/how-fix-broken-nikon-dslr-lens-mounts-3271.html#post125961
The part # and Nikon contact info is listed there as well.
Oct 17, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Dropped the nikon d40x and the lence doesn't want to move in or out sincenikon d40x lens not working since, is it broken??
The camera body or the lens (or both) have been damaged. You could try a different lens (if available) to determine which has failed. Either way, one or the other will likely require repair (or replacement).
Contact Nikon Support:
http://imaging.nikon.com/products/imaging/support/index.htm
Sep 29, 2009 | Nikon D40x Digital Camera
Lens mount plastic is broken on Lens
Unfortunately your lens is one of the kit versions which were built as cheaply as possible with a plastic lens mount. They were never intended to be repaired, but to be fair they usually seem to last quite well on the 18-55mm versions but the 18-105mm is heavier and longer and I've found that the plastic mount is particularly intolerant to any handling errors on this lens.
A professional repair will normally cost more than the lens is worth, but you can sometimes buy new replacement mounts.
Use your favourite search engine to look for part number 1C999-488. Unfortunately they're rarely in stock whenever I've needed one. You may also want to search for a scrap lens with a good mount which you can replace yours with, but scrap lenses of the correct type usually have faulty or badly worn plastic mounts as well.
Carefully assess your lens before making the repair: unless it's in perfect working order in all respects except for the broken mount then you'll be better off buying a new or used complete replacement lens.
Aug 31, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I need a replacement bayonet mount for the above lens.
Unfortunately your lens is one of the kit versions which were built as cheaply as possible with a plastic lens mount. They were never intended to be repaired, but to be fair they seem to last quite well.
Jul 29, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Removing battery chamber cover, nikon d40x
tilt the battery chamber cover by some 45 degrees, and then just snap gently to pull out
Jan 31, 2009 | Nikon D40x Digital Camera
No autofocus
We tried the same lens on another Nikon (D90) and auto focus did not work.
We mounted a new set of lens on the original D40x, and it worked.
Turns out the 2 year Nikon lens (18mm-135mm) was bad. Nikon lens have a 5 year warrantee. The lens will be sent back to Nikon with no service or shipping charge.
Thanks,
K
Dec 08, 2008 | Nikon D40x Digital Camera
D40x Camera with mirror lens = black pictures
Usually tele lenses need longer exposure,and mirror lenses need more than normal lenses.Try with 1sec, half sec,( 2 in the speed dial, not 2" ) or quarter sec (4 in the speed dial) exposures.
One more thing, you need good sturdy stands to hold cameras.
Apr 02, 2008 | Nikon D40x Digital Camera
Cameras Logo
1,255 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
