Hi, This is a relatively new dehumidifier. When I open it all up, it looks brand new inside! No frost, no mildew, all shiny and clean. :) The problem is that I put the bucket in carefully trying to position it correctly.....I hear a little click....it runs for a second, and then stops.
I looked at the red button inside that would make contact with the back of the bucket.....and when I press it (as the bucket would) it MIGHT start....the most I would hear would be a click. If it did start, it would quickly stop. I see what that red button is attched to inside the unit................what is that? And how would I replace it? And where would I get that part? I read all the other messages....I hope I am not asking the same question. Thank you. MizzR
your problem might be with the switch itself. remove the back of the unit. on the lower right side is the switch. with the bucket in place and the unit turned on play with the red or black wire. there might be an intermittent problem. if so look in the manual for the parts breakdown. it will list the part number for the switch. not hard to change. first remove the bucket,then go to the red button and remove the button. behind the button is a nut which holds the switch in place. remove the nut and the switch will come off from the back-----good luck
Comments:
Dec 18, 2007
- also check that the float on the bucket is in properly
i purchased a used kenmore dehumidifier 54351... it turns on when plugged in but then turns off...
(More)
i purchased a used kenmore dehumidifier 54351... it turns on when plugged in but then turns off after a minute or so.. the humidity in the room is between 70 and 80% I would think it should do something... I have played with the dial and nothing changes... the unit seems clean and not well used.. any recomendations on my first step? the switch that detects the drawer is fine... haven't gone any further. is it worth trying to fix?
My 54351 dehumidifier only collects about 1/2 cup of water in a 10 hour period, but after I turn it...
(More)
My 54351 dehumidifier only collects about 1/2 cup of water in a 10 hour period, but after I turn it off for several hours, I later find over a quart of water in the collection bin. The unit is only 6 months old. Should I take it back to Sears?
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended...
(More)
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended period.
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running....
(More)
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running. Kenmore model 580.54351 35 pint Basement is wet and not sure if this model is for basement temps but it works the same in warmer temps.
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change...
(More)
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change the %. It just beeps. the bucket full light flashes even though the bucket is empty. I usually set it on 3 hrs on/off. Have tried powering on/off, etc. Coils not iced up.
