Question about Video Cameras
JVC Gr-ax5-cannot view tapes and has broken lines thur viewfinder
gaya79
  • 31 Answers
SOURCE: JVC GR-D275U Driver for mac
You would need to use iMovie. Most MacBooks come with this already installed but if you can't find it you might have to buy it from apple's website. All you have to do is open iMovie with the camera connected and on and import the movie into iMovie, then you can edit the way you want it to be. iMovie has some great tutorials as well. Importing and editing can take a while, however.
Posted on Nov 08, 2007
  • 169 Answers
SOURCE: JVC Cameras - GR-D70AA MiniDV Digital Camcorder - iris replacement
the ccd image sensor of your camera is the problem...i know it is free for replacing that sensor..that trouble is also in sony,canon,samsung and the other cameras brand cause the manufacturer of their sensor is only one company that why they recall it from the batch of 2002 to 2004..log on to the jvc costumer care to see all the detail...
Posted on Dec 16, 2007
ctf1800
  • 4402 Answers
SOURCE: JVC GR-D33U ERROR CODE EO4
· http://www.camcorderinfo.com/bbs/index.php
· JVC camcorders
· Tap o the side to fix your problems
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
· -I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Feb 11, 2008
rroath49
  • 35 Answers
SOURCE: JVC Gr-DVL300 Won't playback
The heads are probably dirty. First you can try to let a tape run through from start to end and see if it cleans the head. then try running in reverse play scan. Next try a head cleaner tape if you have not yet. If these things do not get your picture back you should take it to a repair shop, I do not recomend taking camcorders apart for cleaning at home. Full size VCR's are ok to clean your self with instructions but not camcorders because they are vary easy to damage worse without experiance and proper tools.
Posted on Jul 31, 2008
  • 586 Answers
SOURCE: Bands or lines on screen during playback
Hi tlaufer ,
              According to the symptom this problem is related to the VIDEO HEAD, As you earlier try to clean the head but no results, Please open the cassette compartment of your camera (as when you insert the cassette in it) for 30 mins (remains open cassette compartment) Actueally some time due to moisture head get durt.
After 30 mins insert the cassette and play it. Hope it will start work again fine.
      But if no result from the said procedure then there must be a damadge of point of the head, in this condition you have to replace the VIDEO HEAD assembly.
Thanks for using fixya.
Posted on May 23, 2009
I have JVC Compact Videomovie GR-AX5. Cannot see anything in viewer. What can the problem be?
Most likely, broken ribbon cable from viewfinder to main board is the cause of the problem.
Dec 02, 2009 | JVC Video Cameras
Error code E03,camcorder shuts down,won't eject tape.How do I fix it.
E03 means the motor drive has failed.The damage is permanent. The camcorder GR-AX5 is too old to repair.Recycle it and buy a new one.
Nov 10, 2009 | JVC GR-AX230 Camcorder
JVC Camcorder- Recording Problems
i have a jvc GR.D20EK and am having problems when recording, it plays back but i cannot record it will play recorded tapes can anyone help me. Thanx
Apr 07, 2009 | JVC Video Cameras
GR-D33u vertical lines on all screens
you'll need to send it in for repairs.
some contact info for JVC.
Stacy Sample Service Coordinator JVC Service & Engineering 10700 Hammerly, suite 110 Houston, Texas 77043 (713) 935-9331 Ext. 101 ssample@jvc.com
being a fact that JVC camcorders are very trouble prone, it would probably be a better ideal & cheaper to buy a new camcorder.
for your next camcorder purchase, i would stay away from anything made by JVC.
Apr 13, 2008 | JVC GR-D33US Mini DV Digital Camcorder
GR-D70U
tape guides need to be adjusted.
Dec 11, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Split screen and blurred vertical lines in view finder and LCD
Elakkis, I am sorry you are having a problem with your JVC camcorder. Your camera more than likely has a defective CCD imager which is being replaced by JVC factory service at no charge because of a problem with the Sony CCD chip being used. Call JVC and arrange to send the camera to them. Hope this helps you! Joe Weibel Custom Electronics (customelectronics.org)
Feb 11, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Blur in viewfinder
Hi, i had the same problem and was suggested i visited the JVC website, this could be the manufacturers error reported on their web site. Failure of the CCD image sensor. Check JVC UK web site, support centre, if your camcorder has the problems listed, until 01/10/07 they will cover repairs. Mine now works ok. Hope this helps
Dec 30, 2006 | JVC GR-D60 Mini DV Digital Camcorder
JVC GR-DX25EK camcorder
JVC has issued a notice on many models that bring up a "lens cap" error. However, the GR-DX25EK is not included. The model you have posted on its page(GR-DX95) is though. This problem is still very common with models that aren't on the said list, given that and the fact that your model is from the same series, you might get some consideration from JVC. No harm in trying. The listed models get a free repair. Heres a link to the notice from JVC: http://www.jvc.com/support/notification/index.jsp?pageID=2 Good luck
Mar 18, 2006 | JVC Cybercam GR-DX95 Mini DV Digital...
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
