Question about Frigidaire (GLMV169GS) 1000 Watts Microwave Oven
Cracks in door of frigidaire microwave over stove
Microwave door has two major cracks in lower panel
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Buttons Not Working
The cycling of your electricity probably didn't hurt it.
Chances are moisture or grease has gotten into the controls. That can ruin the keypad.
The way to prevent that is to be sure you have the microwave's hood vent exhaust fan running whenever you are cooking on the stove top.
If you (or someone you know) might want to replace the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 07, 2008
pyledriver
  • 7 Answers
SOURCE: I think I have a bad door swtich on a frigidaire microwave
un plug the oven, un screw the screws and remove the cover, look behind the door where it closes and you will see a micro switch, and two wirers, note where the wires and screw is located and remove them. get a replacement switch NOTE!! make certain that it is the same type of switch ie. normaly open or nomaly closed. carry the switch you to get the replacement. replace the switch and the wires. if you want to verifry that the switch is defective you can have it tested when you go to the spares store to obtain the new one.
Posted on Jan 05, 2009
  • 52 Answers
SOURCE: Frigidaire door/power problem
Sounds like either the latch assembly or hinges too loose to activate the micro switch. TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 28, 2009
SOURCE: Frigidaire FMV155DC - defective door interlock switch
I had the problem where the timer continues to count down but turntable doesn't turn, fan doesn't come on and food doesn't heat. Holding the door up worked for awhile but even that temporary method stopped working.
I bought a door interlock switch the cost $23 from an appliance repair place and replaced it myself. It worked like a charm. To replace the switch, you need to remove 3 screws that hold the plastic grille above the door, which exposes the 1 screw that is holding the control panel. Remove that screw and slide the control panel up to remove it. There are three switches left of the panel. Note the middle swich has a different part number so I'm not sure what that one is called. The bad one on mine happen to be the bottom one. The switch is held on by a "pin" and tab that holds it in place. Push the tab and spin the switch on its "pin" past the tab to remove. Reverse your step to put the new one on. I hope this helps.
Posted on May 09, 2009
Unlock frigidaire tove
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire stove is not unlocking and you have shut it off at the breaker and pressed clear. You have performed the proper troubleshooting regarding your stove and it appears that you could have a possible problem with the door latch or control panel. I would recommend having a professional technician come out and complete a diagnosis and repair on your stove. I hope this information is helpful. -Matt
Feb 11, 2015 | Frigidaire Microwave Ovens
Frigidaire microwave not working
Is the door closing properly? Do you hear it "click" when it closes. A lot of times the problem is the door switch. It is located inside the microwave. They are made of plastic and they break. If the switch is broken, the magnetron(microwaves) will not start.
Mar 27, 2014 | Microwave Ovens
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
FRONT GLASS DOOR HAS CRACKS
Sounds to me like the door needs to be replaced.
Jul 29, 2009 | Frigidaire FMV156DC Microwave Oven
Crack in the door
You can order separate panels for the door as opposed to whole door, assuming they are still available.
We have the service / repair manuals for this model and have uploaded them to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
May 17, 2009 | Sharp R-1405 / R-140 Microwave Oven
Crack door frame on a microwave over the stove
That's hard to quantify specifically, but the doors use a pretty strong polycarbonate in most cases.
I would say it took a good bump or hit to crack it.
William E. Miller
prototech@usa.net
Jan 17, 2009 | GE JVM1850 1000 Watts Microwave Oven
Jan 05, 2009 | Frigidaire FMV156D Microwave Oven
Remove a door on a microwave
I wouldn't remove the door myself if I were you. If you just got the microwave, it should be under a return/replace policy, or a warranty. I would recommend returning the microwave and getting a sturdier one, as you don't know if the problem exists for all microwaves in that series, and most stores don't allow the replacement to be return/replaced.
Dec 07, 2008 | Frigidaire PLMV168 Microwave Oven
Frigidaire (GLMV169GS) 1000 Watts Microwave Oven Logo
87 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
