Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
  • kingbobb Nov 04, 2008
    DST ended this past weekend, so I thought I'd better check the DVR to make sure we don't miss any shows. The time displayed was 1 hour ahead of current time, so the DVr did not adjust time to reflect the end of Daylight Savings Time.
    Also looking to see if I could reset the clock manually, the Clock Settings (or options, not sure of the exact title) is grayed out, and not selectable in the Setup menus.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Posted on Nov 24, 2008
Clock wont set on Panasonic DMR-EZ48V
set time & date.try change memory ic or" repogram for reset the machine.
May 30, 2012 | Panasonic Televison & Video
How do you reset clock on your DVD Recorder DMR-ES15. Can't find booklet that came with recorder.
You can either copy and paste the following link into your browser, for quick-view, and/or save the .pdf document (instructions for Panasonic DMR-ES15 DVD recorder):
http://videolinq.tafe.net/attached_docs/pdf/equipment/Panasonic_DMR-ES15_User_Manual.pdf
(verified and complete to give you a basic operation manual for FREE download)
or you can try to set the clock manually, do this:
press [FUNCTIONS] on the remote while unit is on, to bring up the setup menu, scroll to 'OTHERS' look for 'CLOCK' or 'CLOCK SET' option, highlight it, click it, set the clock. Press [ENTER/OK] to access the date hour minute, etc., then press the relevant remote arrow buttons to select correct time/date, then press [ENTER/OK] to store the current setting. Then press [RETURN] to exit the setup. Clock is now set (this model does not offer automatic clock adjustment for daylight saving).
If the above suggestion does not work, download the pdf and save it for accurate reference. Either may help you.
May 01, 2011 | Panasonic DMRES15 DVD Recorder
DMR-EX75B - tuning gone with clock
Check that C1801 is not leaky. If so, check if IC1801 has blown. If it has blown, it will also need to be replaced.
Usually it's only C1801 leaky, replace it and thats it.
You can find the capacitor on the main board, under the digital board that has ribbon cables going to the dvd drive.
Hope this helps.
Mar 04, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
How do I reset the clock for the one hour time switch? This was the first DST switch since broadcasting went digital. The loss of the TV guide is no big deal but cannot I cannot change the clock. The...
The Panasonic DMR-EH50 can be reset like it was brand new. I assume the DMR-EH55 can be also. The up and down channel buttons are located on the front of the unit behind the small door in the center. With the unit on press and hold these two buttons for atleast 10 seconds. This will restore the unit like it was new and you will need to go thru set up procedure. The above action will put the unit in the off position. When you turn it on it will guide you thru the set up procedure. Once this is complete you can press the setup button and manually set the clock, however, the unit will need to be shut down for 24 hours to allow the tv stations line-up to be restored.
Nov 02, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DMR-EH75VS
On the EH50, you have to go into Setup Display Front Display and change it to Bright or Dim. Automatic turns it off when power is off
Jan 13, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Clock adjustment
I turned off the daylight savings feature and then adjusted the clock. It can be turned on after making the adjustment.
Dec 13, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Set Clock Greyed out
I have the same problem - clock set is grayed out. Called Panasonic tech support .. this is the solution I was given. It works, but too bad the root problem can't be fixed (bug ridden unit).
Solution is to "reset" the unit - then go back into the menu system and set the clock. How to reset the unit (don't worry - anything on the HD stays intact):
1) go to DVD mode
2) remove any DVD in player & close tray
3) on front panel, behind door - press & hold BOTH channel up & down keys for 5-10 secdons -- until you see a message that the system is rebooting
4) wait till it reboots, go back in the menu and set the time.
-Craig
Nov 05, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Dvd players
For some reason, the clock loast time and is blinking 12:00am I tried going into set but it won't let me set the time. When I press clock in settings, the section to change the time is grayed out. When I do factory reset, nothing happens. How can I get back to the way the DVR was out of the box?
Mar 25, 2007 | Panasonic DMR-EH50 DVD Recorder
Televison & Video Logo
296 people viewed this question
Top Televison & Video Experts
