Question about Sewing Machines
How to thread admiral uht j 2048
Can I purchase a manual
Model uht-j1264. How do I adjust top tension?
Probably your owner's manual is the best source for information. The tension dial usually has a selection of numbers from 0 to 10 (or something similar). Zero is the loosest and the highest number is the tightest. The factory standard setting is somewhere around the midpoint, however, your machine's setting may not be exact.
Be sure that you RAISE the presser foot BEFORE threading the upper thread so the tension disks allow the thread to seat properly.
The ideal tension is when the upper thread and bobbin thread meet in the middle of the fabric being stitched. The tension will probably need to change when you change thread and fabric. You should become comfortable with adjusting the upper tension as it is a integral part of achieving sewing success.
Nov 19, 2015 | Montgomery Ward Sewing Machines
Thread tension regulator fell apart on MW sewing machine uht j 1932
Sorry a search found absolutely nothing that might work for your machine ,
Sep 25, 2015 | Sewing Machines
Need manual for UHT J285E signature
Manual for wards UHT J285E I have a manual..do you still need one?
Jul 30, 2013 | Sewing Machines
I need a manual for a Signature sewing Machine Model # UHT J 285E
Did you ever find the manual you needed? I have one if you want a copy of it
Mar 18, 2012 | Montgomery Ward Sewing Machines
Need a manual for Montgomery Ward Computer 2001 Sewing Machine
I can be reached at thesewinggirl21@gmail.com. I have a copy of the manual for the Montgomery Ward Computer 2001 Sewing Machine.
Feb 29, 2012 | Montgomery Ward Sewing Machines
Looking for a manual for a Montgomery Ward sewing machine model # UHT J1867
I found your manual available at the following website:
http://sewingcenter.us/Wards-Model-UHT-J-276/Wards-Sewing-Machine-UHT-J-276-Manual/ilvm_fly1_blue.tpl.html
It's available for download for a small fee (less than $10). I hope this helps you.
Nov 16, 2011 | Montgomery Ward Sewing Machines
I have my mom's old sewing machine UHT J 1917. I don't have the manual for it and I believe that I have a tension problem. I have loose lops on the underside of my fabric when I'm trying to do a straight...
It more than likely is not threaded right. Insert a new needle, flat side facing away from you, totally rethread with the presser foot up. Now, presser foot still up, pull the to thread, it should feed smoothly, now lower the presser foot, it should barely move. This should seat the thread in the tension discs. Good luck
Feb 03, 2011 | Sewing Machines
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
