Question about Gaggia Brera Coffee Maker
Warning light gaggia brera
There is a warning light showing a red warning triangle with an exclamation mark on it. This is blinking and the coffee machine will not do anything. I have descaled, turned off, unplugged, spoken nicely to and caressed the machine, but nothing is working. Pleading with it has also been unsuccessful so far. Any suggestions greatly appreciated.
SOURCE: Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
Posted on Oct 10, 2007
mirran
  • 515 Answers
SOURCE: Gaggia evolution- water doesnt flow through the brewer
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Posted on Jul 17, 2008
SOURCE: gaggia classic machine
If I understand ...
Sometimes the "gunk" will collect behind the screen on the grouphead. There should be a screw there that you could removed and clean the screen and behind it.
I hope this is helpful.
Posted on Nov 13, 2008
LaPavoniBoy
  • 36 Answers
SOURCE: coffee takes 10 minutes to fill cup and very noisy - Classic
The most common problem with these machines is scale. Using a good descaler to start with may help but may not always solve the problem. If your machine is noisy it is the pump which may need replacing. If you open the steam valve when making the coffee it will shift any air lock. Out with that you may have to remove the shower plate underneath where the coffee handle goes and give it a good clean. Also there is a safety valve inside the group head which may be clogged up. I am a domestic coffee machine engineer based in glasgow and have machines sent to me from all over the UK. It is hard to eally fix problems without actually seeing the machine as it could really be anything. Boilers are small so tend to fill with scale and ****. go to www.theespressoshop.co.uk if you require any more assistance.
Kind Regards
David
Domestic Coffee Service
Posted on May 28, 2009
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
There is a red warning triangle with an exclamation mark in the centre on my machine. What does it mean?
If that light flashes, it means that the service door of your coffee machine is open.
If you can't close the service door then probably the infuser is not pushed in far enough.
Hope this helps.
Sep 20, 2015 | DeLonghi Magnifica Super Automatic...
My Gaggia Brera has all four warning lights blinking simultaneously. And won't make any coffee. Ideas?
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Oct 13, 2014 | Gaggia Brera Coffee Maker
Gaggia brera descale stays on
try to hold the steam/hotwater button for 5-6 seconds.
Aug 15, 2014 | Gaggia Brera Coffee Maker
Gaggia unica red triangle flashing at same time as green cup
Hi there My experience tells me that when a red light flashes on a coffeemaker it is one of three things: It needs water to be able to make more coffee The "bowl" that the compressed coffee goes in ids full and needs emptying It needs cleaning I would start filling the waterholder, Then emptying the compressed coffee holder If neither works, then start the cleaning prosess Best of luck and enjoy your coffee Kolbrun
Sep 18, 2013 | Gaggia Brera Coffee Maker
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
Gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
May 13, 2012 | Gaggia Brera Coffee Maker
Hi, we have received our Gaggia Brera today and it won't prime. We followed all the instructions in the manual and the red triagnle keeps blinking. We're quite desperate to make it work... Any...
Hello, are you turning to the selection knob back to its central position? once you do this the and the unit warms up the triangle should disappear
The icons displayed blink slowly to
show that the machine is warming
up.
When warm-up is complete,
the machine performs a rinse
cycle of the internal circuits.
During this phase, the icons displayed
will blink in sequence.
• When the operations described above
are completed, the icons on the display
will illuminate.
The display will appear as
shown to the side. The displayed
aroma is the factory setting
when the machine is switch on for
the fi rst time, or it is the same as the
aroma that was selected for the last
brewed coff ee.
The machine is then ready to brew
beverages if you have any further questions or the triangle does not go away please message me back for further diagnosis Thank you
Rick
Nov 05, 2011 | Gaggia Brera Coffee Maker
2008 RS 125: red triangle warning light with exclamation mark i...
Hi, Anonymous it's your temperature warning light and I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2008 Aprilia Rs 125
May 17, 2010 | 2008 Aprilia RS 125
Gaggia Brera Coffee Maker Logo
1,246 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
