Question about Hoover Washing Machines
Hoover vision hd 8kg door security button flashing
On starting the hoover vision hd 8kg machine the Door Security button flashes in spite of the door being closed properly and the machine wont start. Help!!!
I now have same problem- did you get a solution?
Posted on Mar 02, 2013
dniro592006
  • 121 Answers
SOURCE: Door wont open, security light wont go off
unplug washer then try it has a magnetic switch that wont allow you to open it
Posted on Jun 11, 2009
SOURCE: hoover HD Vision 8kg washing machine, wont stop
UNPLUG IT
Posted on Dec 27, 2009
SOURCE: hoover vision HD 1400 AAA 8kg washing machine -
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Posted on Jul 18, 2010
kapishtech
  • 2272 Answers
SOURCE: hoover vision HD 1400 AAA,
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
Posted on Sep 18, 2010
SOURCE: After a power cut my washer wont work the door
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Posted on Apr 29, 2011
My hoover dynamic wash 7+ door indicator flashes in spite of door being closed properly and machine wont start
the door interlock has failed and needs too be replaced
you can find this easily changed out part on ebay or from spares suppliers
you usually need to take the top off the machine
power off and open the door and remove the two screws at the lock
reach down and take out the interlock mecha
plug in a new one and put it back and screw it back on
very easy...
Feb 08, 2015 | Hoover Washing Machines
I cannot get my washing machine door to open and alos have error code e07?
On your washing machine control panel you have little icons, find the security. Icon and it should have a line going from it to another button on the control. panel. Press both buttons at dame time and hold till it enters service. Mode. This should make it so the door will open, and will probably tell you what is wrong. with. the machine
Oct 14, 2014 | Hoover DYN8164D White 600 mm Washer Front...
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Apr 24, 2011 | Hoover Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
Feb 01, 2010 | Washing Machines
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
My hoover washing machine 1400 spin 8kg hd vision hd
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
Washing Machines Logo
849 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
