Question about Xerox Documate 250 Path-Through Scanner
Documate 250 does not work on windows 7
We have numerous documate 250s. I installed the driver and all the gray and black documate 250s work. the black and white documate 250s do not work. even on the same machines (just switching the gray one with the white one). They both have the same model number.
  • stephen gee Sep 25, 2013
    I had similar problem Documate 250 under windows 8. No driver (actually its twain support) How to make documate 250 work under windows 1) install vista 64 driver DM250.64.4080513.EN 2) install one touch 4.6 (certified for winows 8) OT4.6.1513.1316.EN 3)take the DM152.ds twain driver. from the DM152_4.6.10.1015.EN and rename it to DM250.ds 3) copy the DM250.ds to the windows/twain_32/ottwain folder
  • Simon Lewis
    Simon Lewis Oct 28, 2013
    Mine keeps asking for admin privliges but I am the only user and an administrator!
Arius
  • 446 Answers
SOURCE: Where to buy Power Supply for Xerox Documate 510
part number 70- 0497-100, you can buy this around 50$ , visit www.superwharehouse.com and provide this part number...
cheers dont forget to mark this pls
Posted on Sep 04, 2008
Binary Bob
  • 91 Answers
SOURCE: Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Posted on Dec 10, 2008
mohanchennai
  • 490 Answers
SOURCE: I have a xerox documate 510 scanner I can not scan
Clean the rubber rollers with Iso Propyl Alcohol. If worn out replace them. Fan the papers so that they are not sticky. This should work.
S. Mohan
Posted on Aug 29, 2009
nyilasrobert
  • 627 Answers
SOURCE: Is there a Xerox DocuMate 510 driver download for
Hi there. Sorry to tell you, but there is no driver for Windows 7. Maybe, soon, Xerox will provide the driver.
Posted on Jan 06, 2010
  • 7 Answers
SOURCE: Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Posted on Jan 10, 2010
Documate 262 driver will not install
check if there is driver for windows 7 on
www.xeroxscanners.com
Feb 22, 2014 | Xerox DocuMate 262 Path-Through Scanner
New driver will not install
I've had this problem several times with Windows 7. Google a piece of software called CCleaner, download, install and run it. It removes registry problems, bad installs and other extraneous fluff, speeding up your machine, preventing malware attacks and making fresh installs easier. That should clear out the gunk files that are stopping the new drivers from installing. (Between running CCleaner and installing the new drivers, though, I strongly recommend restarting.)
Aug 31, 2012 | Xerox Corporation DocuMate Sheetfed...
Is there a Xerox DocuMate 510 driver download for Windows 7?
Jan 06, 2010 | Xerox DOCUMATE 510 Flatbed Scanner
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
184 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
