Question about Garmin GPS
Garmin nuvi 2595 will not take a charge
After 2 uses, battery seems to be dead and will not charge.
I found my brand new nuvi 2595lmt repeatedly power cycling and loosing its charge when I tried to charge it (for the second time as well). I was using a different USB cable. When I switched to the supplied cable with the "Garmin" insignia on it, the problem resolved. Hope that helps, good luck.
Posted on May 26, 2013
SOURCE: Dead Garmin
I had the same problem - worked great for a year and yesterday was totally dead - not a hint of powering up.
I pulled the blue front "frame" off and held the reset button for about 5 seconds. It powered back up and works like a champ!
-Johnnyx
Posted on Jun 07, 2008
SOURCE: how do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Posted on Dec 03, 2008
SOURCE: Garmin Nuvi 660 dead battery?
Normal 0 Garmin NUVI 660 instructions
It is pretty easy to open up your nuvi,(but not recommended by Garmin or me)...
looking at your nuvi from the back flip up the antenna. You will see two tiny torx screws on the antenna. Remove them and carefully seperate the antenna housing. Pay attention to how the antenna flex is seated because reassembling the antenna housing can be tricky. On the left bottom side the pin assembly that holds the antenna in is spring loaded. Pull the pin towards the center and you will be able to seperate the antenna housing from the unit. Underneath you will find two more tiny torx screws holding the main housing togather. Remove those two screws and you are almost home. Now you need the special plastic tool that you can get on ebay. The tool is used for opening ipods without mangling them. Gently pry the case apart with this tool. Start where ever it is easiest to get the tool in. Once opened you can figure the rest out for yourself. The battery is flat and rectangular and is seated behind the circuit bourd attached to the back cover.
Posted on Dec 26, 2008
RixsFixes
  • 2200 Answers
SOURCE: Charging Garmin Nuvi battery for first time
The Garmin Nuvi 855 uses a Lithium-ion battery. It is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge.
In other words there is no memory effect with these batteries and it should be safe to charge it for as long as you like on the first charge. I would estimate 4 hours will give you a full charge if you wish to do this from the outset.
Posted on Jun 21, 2009
pabloloco
  • 2335 Answers
SOURCE: Garmin Nuvi will not load maps - why
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Posted on Jan 15, 2010
Whats wrong with my nuvi 2595 satnav
Check the region you are using in your search. If the addresses are outside the region selected, the GPS won't find them.
Aug 02, 2016 | Garmin Nuvi 2595 LMT GPS
Will not turn on, with or without charging
The Nuvi 25x5 is well known for having issues with the rear USB port becoming loose or disconnected from the PC board. This will prevent the unit from powering up when connected to an external charging source. It will also prevent the internal battery from being able to be charged, so when the battery has exhausted its charge, the unit will be dead. This can be repaired. For more information, please see this link: SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 18, 2016 | Garmin Nuvi 2595 LMT GPS
My device will not switch on I have been charging it all day. The charger is working
Under the circumstances iterated, your Garmin has gone to GP heaven. Repair is not cost effective with those things.
Dec 27, 2015 | Garmin Nuvi Nuvi 2595 2585TV 2545 2515...
Why the garmin nuvi 2595 is avoiding freeways
No. it depends on your settings. You can choose fastest route, shortest route or to avoid like toll, U-turn, ferry, or..... check your settings and reset it as suitable for your driving situation.
Feb 21, 2015 | Garmin Nuvi 2595 LMT GPS
Why doen't my garmin nuvi 2595 turn on?
Is the battery dead? Try it with the external power attached, see what happens. If still no go check the fuse in the end of the car charger, it may have blown.
Aug 29, 2014 | Garmin nuvi GPS
My garmin nuvi 2595 lmt will not turn on, recharge, nothing but a black screen. I pressed what i think was the reset button several times but nothing. Once I heard a sound as if it was going to turn on...
Take a look at rear USB port. Insert the plug. Gently wiggle the plug. Does the USB port appear loose? A common problem with this model is that there is little mechanical support for the USB connector. If it breaks off of the printed circuit board, there battery will nit be able to be charged and the unit will appear dead. Have you tried holding down the power switch for at least 10 seconds?
Aug 14, 2013 | Garmin nuvi 200W GPS Receiver
I battery went dead. I have pluged it into my computer . It lights up and shows a picture of it attached to the computer and the word Garmin but it does not show it chargeing.
Please leave it to charge and after about 2 hours - check it.
The Garmins need an initial charge to run - it is not bypassed if dead. It will not run on adapter power.
If it will not charge in vehicle or home - the jack may be loose from the board - but more likely the battery has failed.
Garmin DOES repair for a flat fee - units that are OUT OF 1 year WARRNATY CLICK HERE.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Garmin nuvi 265 Car GPS Receiver
Power cord doen not seem to recharge Garmin Nuve 680 in car.
to register my Garmin Nuvi. I want to get it registered, I tried before I'm not sure how far I got if it is registered or not
Jan 15, 2009 | Garmin Nuvi 680 GPS Receiver
GPS Logo
2,630 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
