Question about Grilling
Weber gas bbq
My weber gas bbq (kettle type) is not igniting properly, in that I only get a few of the flames coming through the small holes after I've switched the gas on and placed a match to the small holes in the element at the base of the bbq.  Any suggesitons?
    Scholar:
  • 157 Answers
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Posted on Nov 12, 2008
Frontier BBQ flame at insertion of gas to burner and not going along the small holes
Air mix could be wrong , burner not lined up with injectors burner out of postion
Sep 15, 2012 | Grilling
Can i get a replacement switch for the ignition weber 200 switch will not ignite the gas there is no spark coming from the switch
First, you want to make sure the end of the piezoelectric switch is close to enough to something metal to spark. Maybe it got displaced when you cleaned the bbq?
If it is close enough to arc, but doesn't spark, you can replace the switch with this kit here:
http://www.grillparts.com/weber/Q200.asp?product_id=QSPARK
Good luck, and if this helped, please rate my response! Thanks!
Mar 22, 2011 | Weber Q200
I gave my Weber Q a clean, using a BBQ spray cleaner. Since then the flames are yellow and not blue as before and the heat is insufficient to cook , and the flames go out when the lid is closed. Any...
Either the cleaner you used is partially clogging the burner holes or you inadvertently moved the air adjustment and are starving it from getting the air it needs to burn properly. Douglas
Sep 08, 2010 | Weber Q Grill
Weber Silver BBQ has 3 burners only 1 has normal flame.
you may have to remove the burners and clean the inside of them. they could have insect webs inside preventing the flow of gas. hope this helps. also, try opening the tank really slowly.
Oct 12, 2009 | Weber Grilling
I just hooked up an LPG bottle and hose to my Weber Q, and when I light it, the flame is very weak. In fact, the flame extinguishes after about 10 seconds. I can't seem to get the proper flow of gas to...
if using the adapter hose for large tank weber has had problems with hose call weber and get new one or call bbq galore and ask for a 4ft. adapter hose 214-696-0030
Aug 10, 2009 | Weber Q Grill
Turn on,the closest tube only has a few lit
I have a 10 year old Weber and this has happened a few times to me. I just pull the grills off and then the flavour bars out . I take my wirebrushs and scrape off the holes on all three tubes. Light the BBQ and test to see if all of the holes are burning. Id their are a few still not producing a flame use the wirebrush on the tubes again. Please try not to burn yourself. Once the holes are clean and burning well - replace the flavour bars and grill. (I suggest you cleam your BBQ once every 6 months depending on your use). Good luck
Jul 28, 2009 | Weber Genesis Silver B Grill
Low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Jul 03, 2009 | Weber Genesis E-320 Propane Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
The gas is coming through, but does not light.
I have the same grill,and sometimes the same problem.First,with the gas off or completely disconnected,remove the grill grates and the flavor bars from the grill.Now you can see the heating element.A small wire brush will do the trick.Gently clean all the little holes in the element where the gas comes out.Then,with compressed air or even canned air(like what you use to clean a computer with)blow out the holes you just cleaned.Reassemble the grill and light.Should work fine after that.
Dec 28, 2008 | Weber Genesis Silver B Grill
Grilling Logo
221 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
