My electrolux intuition is not washing . It has stopped turning
Intuition 6kg Eco valve
fanny
  • 146 Answers
SOURCE: eco intuitive washing machine
The rotor position sensor is faulty or corroded. You will need to remove the motor to access the RPS. It is a small electronic board that slides onto the coils of the motor.
Posted on Nov 03, 2007
  • 92 Answers
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Posted on Feb 22, 2008
SOURCE: Fisher & Paykel intuitive eco washing machine
How do I fix a code 37 on my machine
Posted on Aug 31, 2008
SOURCE: Intuitive Eco IW811 washing machine
I have the same problem , was told that it is the RPS rotary positioning system, cost about $200 to get someone out to fix it.
Although I did reboot it and it went through the wash ok.
Posted on Sep 01, 2008
SOURCE: Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Posted on Jan 13, 2009
Pumps out instead of recirculating
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
High limit switch gas hot water giant
Tank-type Gas water heater: high limit can the FV system, the ECO-TCO reset located on front of combustion chamber, or the one-time-use ECO located in the gas control valve thermostat probe.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-20.jpg
http://waterheatertimer.org/images/Gas-valve-ECO-124.jpg
Tank-type electric water heater has a reset button:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Other types: Tankless, indirect, boiler, solar assisted, hybrid, etc, please refer to product manual or add comment and describe the product in detail
Apr 07, 2013 | Water Heaters
LG Intuition won't turn on, black screen, pulsing lower buttons
Lg Intuition won't turn on...
That happens to my and I tried to many different things like different chargers, reset, overcharging etc etc...
But I was about to sell it as parts when I decide to swap battery with my brothers intuition phone...
Its not hard to do it you can do it yourself. ..just remove the screws in the bottom and carefully release the battery cover(don't broke it cuz it works as ANTENNA)
remove the screw that is covering the battery plug then unplug the battery...remove it and insert the other one...LISTO!!!!!
do the same process with ur battery in other intuition phone...
What happens ita that the battery has a chip that block the connection with the phone when you let it die so after the battery detects a different device it reset itself. ..hope this help you people...any questions let me know...also the best place to buy a battery is calling LG CORPORATION. ..it retails around $20-$25
Feb 14, 2013 | LG Intuition
My Rheem water heater is giving a ECO failure, How can I fix this?
Question posted under Rheem water heater.
Model number and gas valve are unknown. Add a comment.
Following information applies to typical tank-type gas water heater, and does not apply to tankless water heaters, boilers, indirect heaters, solar water heaters, etc or for electric water heater.
Electric water heater ECO is located on upper thermostat.
Open top cover and ECO can be reset by pushing in red reset button,
Or ECO can be replaced by replacing thermostat. Add a comment.
Open following link to see typical tank-type gas water heater ECOs:
http://waterheatertimer.org/images/Intellivent-ECO-900.jpg
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
The ECO will trip at 180-200 degrees F.
This happens when the thermostat fails, then the burner stays on, and the water will continue heating.
With most water heaters, the ECO is one-time use device and the gas control valve is replaced.
Some water heaters have resettable ECO, but the overheating problem has to be solved.
Each water heater is different.
Contact Rheem or read manual for correct procedure.
If you have intellivent gas control valve, open following links for typical service manual:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
It says if my ECO has tripped the water tempature has exceeded 200F. What would cause the tempature to reach 200F
Question posted under Rheem tank-type gas water heater.
Open following link to see typical ECOs:
More resources:
Sep 30, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Automatic restart is not working. Seems to keep saying eco problem...I thinl...the code is four flashes followed by two flashes.
Gas control valve is not identified, so error code is not known.
ECO means energy cut off.
Energy cut off happens when gas control valve thermostat has gone bad, or when gas control senses runaway heating inside combustion chamber.
Newer heaters have resettable ECO for combustion overheat. This reset is typically located on combustion chamber door and is round and has two wires that connect back to gas control. Generally you have to clean combustion chamber and tubes and catch up on maintenance, then reset ECO, then fire up heater again to see if problem is resolved.
Newer heater does not have reset for bad thermostat, and in that case you replace gas control valve thermostat.
Older heater does not have reset, and combustion chamber and parts are cleaned, and gas control valve thermostat is replaced.
Your manual is best place to start troubleshoot.
Open following link to help identify gas control valve:
Jul 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Low voltage to eco from switch board will not hold valve open
That 12VDC voltage comes from battery and/or converter. Try unhooking battery while plugged in, and see if lights stay bright, as well as check voltage at screw terminals where fuses are in fuse/breaker panel. I f voltage low from converter, check the main fuses at converter. Be sure to check all fuses to circuits as well. You may have a bad or corroded connection from fuse panel to ECO as well. Remove wire from opposite side of ECO where it runs to gas valve, and see if voltage returns to acceptable range, indicating poor connection to valve, or valve drawing too much current.
Let me know what you find.
Mar 07, 2011 | RTO Atwood Water Heater - 6 Gal LP
Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
Jan 08, 2009 | Haier Washing Machines
Washing Machines Logo
253 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
