Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Channel reception The TV is hooked up to cable and channels 3-10 come in finn but all the upper channels at not viewable. The remote is not the orginal because I purchased this as open box item. I did try to scan the channels in with the remote the store supplied. Any suggestion as to how to recieve the other channels
  • 3 Answers
What you need to do is go into the menu and go to channel programming and switch the TV tuning mode to cable and it will scan and recive all the channels. Good luck
Posted on Aug 20, 2006
TV is hooked up to cable and I hit the channel up Arrow on the tv remote,now message on the screen that says please run channel automatic search. message does not go away cannot use my cable remote
how do you have the cable hooked to your tv? Is is hdmi? Is it the antena jack? Your tv is asking you to run the channel program because the cable is hooked to use channel 3 or 4
Dec 03, 2017 | Televison & Video
Tv cant find a channel, all i get is snow
First ensure that the signal reception from your local cable provider is not the issue here. Ensure also that the cable plug is properly connected to your tv.
If the symptom still persist after you confirmed that the signal is good from the cable, this is an indication of faulty tuner in the main board. This is responsible for processing the viewable channel available.
Analog/Digital Tuner : part no. (EBL34917003)
Replaced this part and your unit will get all the channels again...
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 16, 2011 | LG 47LC7DF 47 in. LCD HDTV
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
Auto channel search.
Check the r/c[remote control] for ' fresh ' batterys.
Do you have " air wave " reception? or cable connection?
air wave reception will scan but cable reception can't scan because the channel is 'fixed' at ch.3 or ch.4.
Nov 30, 2008 | Olevia LT42HVi 42 in. LCD Television
Tv/vcr combo wrong cable channels
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
Sep 12, 2008 | Philips 43PP9202 43" Rear Projection...
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Missing channels
no they are not related. ur tv seems to have a defective tuner(inspect also for possible cold solder inside the tuner). remote control can be clean using a cotton swab with a little isoprophyl on it. clean the contact on the pcb.
Jan 14, 2007 | Samsung TXN2745FP 27" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
