Question about Indesit W 123 Front Load Washer
Demontare indesit wie 127 x - Indesit W 123 Front Load Washer
3 Suggested Answers
SOURCE: Indesit WIE 147 - Display 'F-03' fault
have had my machine 2 years ..has f-07 display( WIE157S)....cycle seems to stop...can anyone help???.
Posted on Nov 11, 2008
  • 136 Answers
SOURCE: it flashes f o7 on my wie 127
hi sir, It seems that a common error code on Indesit washing machines is error code 7. This code can show itself as F 007 or with washing machines that have a rotating control dial the door lock light can flash in cycles of seven times.
This error code usually means, “heater relay stuck”.
The heater is switched on via a relay built into the main PCB. This relay is known to get jammed causing error code 7. In my experience this has usually meant a new PCB needed fitting and as the PCB comes without the main processor EEPROM chip one of those is needed also.
This repair is going to be expensive. I have heard anecdotally of engineers freeing off the jammed relay by giving it a firm tap. However, I would not expect such a repair to last as the chances are the relay would just get stuck again later on.
If a washing machine is still under the five-year parts warranty it would be cheaper to let the manufacture fit these parts but although the parts would be free the labour is going to be about £90.
kindly rate me..
thanks for using fixya..
Posted on Feb 12, 2010
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
It flashes f o7 on my wie 127
kindly rate me..
Feb 12, 2010 | Indesit Washing Machines
Indesit wie 147 F-12
F12 indicates a communication error between boards.
Check all connections to the boards.
Jan 16, 2010 | Indesit Washing Machines
Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
Jul 05, 2009 | Indesit WA 125 Front Load Washer
Indesit wise 127 x F-10 error on the screen
F10 means no cold fill.
Check cold water supply, and check drain out let hose is not kinked.
Please rate my soilution.
Thanks.
May 20, 2009 | Select Brands Washing Machines
I have an indesit WIE 137S. When the door is closed, teh red door lock light does not come on and the wash can't proceed. Any hep greatly appreciated
Have you checked your plug and the connections, also your socket.
If no joy, then door lock probably faulty.
Nov 18, 2008 | Indesit Washing Machines
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Indesit W 123 Front Load Washer Logo
76 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
