Question about Sony CDX-F5500 CD Player
How to turn Demo mode in Sony CD Genezi
It won't turn off unless i pull out the plug.
2 Suggested Answers
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
IPhone 4S won't turn on
Try holding down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone and should resolve your problem!
May 01, 2013 | Apple iPhone Cell Phones
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
My mcculloch 10-10a won't turn-over
That sounds like hydro lock. Usually happens when an engine gets flooded for various reasons. But you would see fuel coming out of the spark plug hole when pulling it over. Does it turn over at all with the plug in it? As crazy as it sounds an incorrect plug (length) could cause contact with the top of the piston so the engine would turn over fine up to the point of the piston coming to the top of the stroke. Another wild guess would be an exhaust port/muffler so plugged that it won't let anything out.
Aug 23, 2012 | McCulloch Garden
My samsung doubletime won't turn on unless it's plugged in
REMOVE BATTERY > Clean the terminals specially middle terminals of both battery & phone with dry cloth.install battery. If the problem persist then change battery.
Aug 07, 2012 | LG enV VX9900 Cellular Phone
1987 volvo headlights won't turn off unless i pull the relay or disconnect the battery?
check all wires around or closer to your parking brakemaybe you have a short or your swich is no good.
Jul 23, 2012 | 1987 Volvo 240
2001 f350 won't star unless pluged in
Sounds like it's the controller for the glow plugs, also, if the first glow plug in line from the controller is bad it will effect all the others. I've had this same sitituation, mine turned out to be the controller.
Jun 10, 2012 | 1993 Ford F350
Turns over but won't start
see if your getting power to the solenoid on the bottom of the carb
Apr 15, 2012 | Garden
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
Sony CDX-F5500 CD Player Logo
208 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
