Question about Emerson EWC13D4 13 in. TV/DVD Combo
My EWC13D4 remote isn't working properly
The only thing that works on it is the channel up (not down) and the #3 (I can only use it to get to channel 33, I cannot press the 0 to get channel 3)! We cannot control the volume or power or DVD with the remote. Please help! this is very annoying! I have put good batteries in it as well! Thanks Coopette
    President:
  • 3,130 Answers
Your remote is bad that you know. Is it worth fixing it> No, Highly unlikly. A universal remote for about 10 bucks can be used to change channels and volume as well as the on and off funtions BUT a universal remote will not work the menu or any of the other feture. Go to the link I posted here to find your remote you need to get... good Luckhttp://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=EWC13D4&brand_pn=EMERSON_EWC13D4&mode=large&uid=1156107437374
Posted on Aug 20, 2006
Can select channel by entering the # but when using the up/down channel arrows, goes straight to channel 3
You are using a universal remote control I assumes. Try with an other setup code. Some setup codes might not work for all button actions properly. Choose an other code, which will give you maximum functionality.
Jul 05, 2012 | Toshiba Ct90325 Remote Control
I need to access the setup menu on my emerson ewc13d4 without the remote
No, you are stuck and a universal likely will not have key functions you want.
Mar 19, 2012 | Emerson EWC13D4 13 in. TV/DVD Combo
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Need code for ewc13d4 tv/dvd for direct tv remote
Direct (and Dish) may not have codes available for all brands and models; I know that from personal experience.
You need to got to Direct TV's website to obtain a current list of codes. Even if they have some for Emerson, they may be quite limited in their usefulness.
Nov 24, 2008 | Emerson EWC13D4 13 in. TV/DVD Combo
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Remote control
Is this a new condition?
Or has it operated differently in the past?
If you are connected to any kind of box (satellite for example), there is only one channel that the TV sees; usually 3 or 4.
The channel changes are limited to the box.
Aug 22, 2008 | Initial HDTV-322 32 in. LCD Television
Programming
You need the original remote to change anything in the menus of the set. With a universal remote, you can manualy change the channels, but you cannot sequence them or change any of the setups to have them work automaticaly.
All TV manufactures are like this.
Call the authorized service rep, and order a new remote, or find the original if you want to be able to use your set properly. Don't accept a universal remote, because this will not properly resolve your issue.
Jerry G.
Jun 29, 2008 | RCA TruFlat 27F520T 27" TV
Polaroid remote channel button does not work
This looks to be a good hint. After reading the solution "I had the same problem. The fix is actually very easy. Just re-tune your channels in and your remote/channel buttons should work again.", I checked my remote and saw that there was a sliding button "TV/Cable" and it was on "Cable"
I moved it to TV and it started working.
This could be a dumb solution but just wanted to suggest...
Dec 06, 2007 | Televison & Video
Emerson EWC13D4 13 in. TV/DVD Combo Logo
239 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
