Need reset code for gestetner 2718z copier drum
Drum reset code
SOURCE: Gestetner CP6123 giving error E12
You should check the all paper sensor, there must be a pieces of paper in some sensor and make the sensor in wrong direction. You should remove all and off the power for a while and the start to use it.
Posted on May 12, 2008
  • 42 Answers
SOURCE: Gestetner 2718Z copier Error Message
low temp.in fuser unit. may have blown fuser lamp
Posted on Jun 20, 2008
  • 990 Answers
SOURCE: Copier drum reset code
Hello sir; The simulation code for reset drum counter at this model is # 20 sub code07 if need more help let me know.
Posted on Jan 05, 2009
  • 67 Answers
SOURCE: Need reset code for Sharp AL1631 copier drum
USING ONE FINGER PRESS CLEAR, AUTO(EXPOSURE SETTING), CLEAR & AUTO YOUR DISPLAY WILL GO BLANK, IF IT DOESN'T GO BLANK TRY IT AGAINSOME MACHINES ARE TEMPERMENTALWHEN YOU GET IT GO BLANK PUNCH IN 24 THEN PRESS THE START KEY THEN PUNCH IN 07 AND THEN PRESS THE START KEY AGAIN. THAT WILL RESET THE DRUM COUNT. TO GET OUT OF THAT MODE PRESS CLEAR A COUPLE TIMES OR TURN IT OFF & BACK ON
Posted on Apr 10, 2009
SOURCE: Gestetner 2822 error code e-5
i got a strait black thin line on left marging of paper. i think margin setting of my Gestetner 2822 has been changed. but i don't know how to fix this problem. (107-C, ???)
Posted on Feb 15, 2010
Gestetner 5308L error says set drum completely
Please open the front door carefully and open the right door also and then remove the photoconductor unit unit and reset properly.
If the problems persist , call an expert to check the sensor for you.
Best of luck.
Apr 18, 2014 | Gestetner DSm627sp All-In-One Laser...
User code
SP 7810 Acces code clear.Resets both the key operator code and the weekly timer code.key operator code for OFF setting.Press START to reset.
Feb 01, 2013 | Gestetner DSm735 Black and White Copier
I have Gestetner DSM 730 and it give me an error of serial no: k8654300136, so the problem
how can I reset one copy Gestetner DSM 730 if screnn touch does not afiche we do not even know the code up above.
Feb 11, 2012 | Gestetner DSm730 Black and White Copier
Our Gestetner DSm415pf printer has a photoconductor light on, needs to be replaced. Where do we purchase this and how do we find out the method to replace this. Manual? We don't have.
It's very easy to replace the drum unit. When you find Photoconductor unit there is a simple instruction on the box. You have to search for photoconductor unit type 1515 (also look for nashuatec, rex rotary, infotec or ricoh brands to see where you can find it on best price - 100EUR).
If your mashine is printing fine, there is no need to replace the drum. You can only reset PM counter display if mashine stops.
all the best
pifonski
Apr 07, 2011 | Gestetner DSm415pf Digital Imaging Sytem
I have a gestetner 1312 copier it says reset pcu proprly.what does this mean.
The PCU is the drum unit. It probably has just worked loose. Just unlatch it and shove it back in to make good connection in back.
Jul 27, 2010 | Gestetner Office Equipment & Supplies
How can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
Aug 19, 2009 | Gestetner Office Equipment & Supplies
Jun 15, 2008 | Office Equipment & Supplies
May 11, 2008 | Gestetner - AO40 Wide Format Copier Copier
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
jasbo
jasbo
