Question about HP Office Equipment & Supplies
HP L7580 All printing is coming out in a mirror image - back-to-front. Please can you help?
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
there is a setting to configure
before you can print!!!
try to re-install the driver f your printer
Posted on Oct 26, 2008
Mirror image printing with my HP L7580 printer
Turn the mirror image option to on. If it does the same turn it off than uninstlall and reinstall the complete software.
You can access this when you click print, select either the options or properties button depending on os
You can also access this by righht clicking on your printer for properties
May 11, 2011 | Office Equipment & Supplies
When I print pics off my pic file, the pic comes out in a mirror image? I am using a HP Photosmart 3210 All-in-One Printer. Also when I try to print 4x6 pics from my files using proper HP paper, it tells...
When you go to print something next time, click on Preferences on the Print window. Click on the Advanced tab. There should be a Mirror Image choice and it probably says ON. Click on the ON and change it to OFF with the drop-down menu. Click OK. That should correct the mirror image problem.
As for the paper, I have a hard time printing on 4X6 paper too. Seems to be a common problem with HP. If you would like to accept the mirror image solution and post a separate on, you should get another expert to help you.
In the meantime I will try to research it further.
Thanks for using Fixya.
Dec 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printer is printing job as a mirror image
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
Apr 21, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7580 printer prints mirror image
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printer printing backwards on two users but not the main one
Compare the default printing preferences (Start>Settings>Printers and Faxes) Right-click on the printer icon and select Properties and Printing Preferences. Look for the option to print Mirror image used for printing T-shirt Iron-ons and uncheck the box.
Jan 03, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
  • Go to the Printers Menu and select Add Printer
  • Add a Local Printer
  • Create a new port - type: local port
  • For the port name, enter the share of your printer on the remote computer.  For example, if your computer name is superDesktop and the printer share name is megaPrinter, you'd type in \\superDesktop\megaPrinter.
  • Finish the wizard and you're done, printing normally!
Oct 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
I have an HP Officejet Pro L7580 and for some reason it is printing back to front. The only way to read it is to put it in front of a mirror. Can you help?
  1. Go to the HP print settings box.
  2. Click File and then click Print .
  3. Click Properties , Setup , or Printer .
  4. If you still do not see the box, click Setup , Options , or Properties .
  5. -OR-
  6. If Print is not there, then click Printer Setup or Print Setup .
  7. Then click Setup or Options .
  8. In the HP print settings box, click the Features tab, and then uncheck MIRROR . Click OK .
try this steps and send me feedback to give you further troubleshooting steps if needed..
Sep 01, 2008 | Office Equipment & Supplies
Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Aug 12, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
60 people viewed this question
Ben Johnson
