Question about Printronix P7220 Matrix Printer
Delete data in buffer
Building printer on AS/400, deleted printer from AS/400, cleared out spool file, printer still printing
2 Suggested Answers
SOURCE: AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Posted on Nov 16, 2010
How do you clear the print jobs so that you are not printing the same things over and over
How to Clear Out a Stalled Print Job In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Once you have restarted the Print Spooler, the jammed print job will be cleared from memory. Now you can go back and re-print all the jobs that were held up.
Feb 15, 2011 | HP Office Equipment & Supplies
How to clear the memory on a Samsung ML-2855ND?
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • Open My Computer.
Sep 16, 2010 | Samsung ML-2855ND Laser Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Aug 19, 2009 | Lexmark Office Equipment & Supplies
I can't "delete" a document from the que
Option 1)
Click on start orb
services.msc
click ok
window.
stop
Option 2)
folder.)
It is located in:
00002.SHD
00002.SPL
Apr 10, 2009 | Lexmark International Z611 Printer
Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
Apr 10, 2009 | Dell 966 All-In-One InkJet Printer
How do I clear an incomplete print operation?
Try clearing your spooler queue:
Delete the spool printer files loadTOCNode(2, 'resolution'); In safe mode, delete the spool printer files. To do this, start Microsoft Windows Explorer, and then delete all the files in the following folder (where C: is the drive where Windows XP is installed):
  • C:\Windows\System32\Spool\Printers
Dec 08, 2008 | Lexmark Z600 InkJet Printer
I have a Lexmark 2500 series printer. There is one printing job that I try to cancel. When I chose the cancel option, the status of that job changed to deleting... and has been like that for the last 24...
I assume you've turned everything off and back on again, including the printer and the job is still stuck.
For windows XP,
click on the start button, click on run
type
net stop spoolsv
click OK
wait 30 seconds
type
net start spoolsv
click OK
Open the printer and refresh the print queue, has the job cleared?
If not we will need to clear the temporary spool files from the spool folder.
type
net stop spoolsv
click OK
The usual path to the spool folder is
C:\WINDOWS\system32\spool\PRINTERS,
Delete the files in this folder only, if you are not sure do not delete them.
Close this window.
type
net start spoolsv
click OK
Alternatively, if you are comfortable using the run command, do the following in sequence. Be very careful what you type *.* means everything in the folder.
net stop spooler
del %SYSTEMROOT%\system32\spool\PRINTERS\*.* /q /f
net start spooler
/Q - for no prompt
/F - to force the deletion
Dec 02, 2008 | Lexmark Office Equipment & Supplies
Deleting Files from spool after they have printed
see your Spool settings, Set Print directly option and try.
Apr 09, 2008 | Lexmark X6100 Flatbed Scanner
Problems deleting printed files from the spool
Navigate
Start-> Control Panel -> Printer
Right click on printer icon and select properties
Find out Advance settings. See Spooling, Select Print Directly and try.
Although your driver looks like incompatible but above will fix your problem.
Thanks
Iqbal
Printronix P7220 Matrix Printer Logo
74 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
