Question about Dell Inspiron Mini 10 Notebook
My 1018 mouse buttons do not work...both left and right
I was using my laptop one day and it was going fine and then i tried to click on something and it didn't work. I am very reliant on these two buttons so was wondering if anyone knew how to resolve these issues?? I have checked to see if it was disabled some how but it is all enabled.. Can someone PLLEEAASSEEE help me...the touch pad works fine
Pyrhyc
  • 2028 Answers
SOURCE: disable touch pad on my Dell Inspiron 6400 notebook
Open the device manager, then open the touch pad, then you will see the enable/disable option towards the bottom.
Posted on Aug 21, 2008
  • 170 Answers
SOURCE: DIsable touch pad on Inspiron 1501 laptop with XP
You should see a touch pad icon in the task bar. Right click it and disable device in the device select tab. Good luck. Let me know how you made out, and please rate my answer.
Posted on Jan 20, 2009
  • 80 Answers
SOURCE: how do i enable my laptop touch pad
Click the buttor or if you use windows go Start -> Control panel -> Mouse -> Synaptics and enable your touch pad.
Posted on Aug 08, 2009
  • 15 Answers
SOURCE: HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Posted on Sep 04, 2009
  • 72 Answers
SOURCE: Touch pad doesn't seem to work and dosn't come up
HI,
TOUCH PAD DOESNT WORK,IF U R TECHNICIAN OR FAMILIAR WITH ELECTRONICS,SO DESEMBLE LAPTOP AND SEE WHETER STRIP OF TOUCH PAD IS CONNECTED TO MOTHERBOARD OR NOT.
TNKS
RABBANEES
Posted on Nov 04, 2009
Testimonial: "I believe it has something to do with the touch pad driver"
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
Mouse buttons left right switching sticky keys
Remember you can always use the keypad in place of the mouse. Try replacing the mouse with another one. If that doesn't work, it is probably something in the software. Do a scan on the system next.
Jan 31, 2013 | Microsoft Computers & Internet
Left mouse button works like the right betton. The right button works ok. With external mouse both buttons work fine
Go into Start > Control Panel > Mouse and check the macro settings for your left and right mouse buttons. If those are fine, then check the macro settings in the program you are using. Make sure your mouse isn't set to do the same thing for both clicks.
If that doesn't work, go to Samsung's website and download the latest drives for your touchpad. Reboot the machine and check it again.
Feb 14, 2011 | Samsung R530 Notebook
I am having HP laptop. For last 2 days my touchpad
try reinstalling the driver for the mouse pad
that should go fine
Jan 05, 2010 | HP Compaq nc6220 Notebook
Left-handed touchpad control buttons
Go to start....
Control Panel....
Mouse....
Buttons....
Select left handed...
That should do the trick...
Nov 23, 2009 | Toshiba Satellite A105-S4074 Notebook
Laptop Acer Travelmate 2300 Sticky Left mouse button HELP!
If you have the disk remove/reinstall the mouse
no disk , search the make and model
No mention of which OS your using so let me know if you need more assistance
If your using XP try this
Go to start
control panel
add/remove
device
remove
reboot
reinstall
Hope this helps , let me know outcome thanks
Jul 13, 2008 | Acer TravelMate 2300 Notebook
Left click for mouse does not respond - right click very slow
replace the keyboard with one from eBay that would be the least costly way to repair the problem. sounds like the cable has been damaged for the keyboard to motherboard interface. have you tried connecting a mouse to the usb port or the ps2 port on the back? that may solve the problem if you don't want to replace the keyboard
Apr 24, 2008 | IBM ThinkPad T40 2373 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Dell Inspiron Mini 10 Notebook Logo
26 people viewed this question
Alun Cox
