Question about Sony Televison & Video
How to use remot control sony wega RM-yd002
How to use Remote control
  • 579 Answers
SOURCE: Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Posted on Jan 08, 2008
SOURCE: Insignia TV code for Sony remote RM-V302
press tv, hold setup til tv blnks twice and release setup, type 10463 then power. 5 digit code not 4 like most.
Posted on Jun 19, 2008
VOTIT
  • 2071 Answers
SOURCE: a cytron tv
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 26, 2008
SOURCE: sony kv-21x1u
Press and hold for a few Seconds the 2nd Button from the left on the front of the TV. The auto tune menu will appear on the bottom right of the screen. Wait until it disappears and then check the channels by using the buttons on the remote.
Posted on Oct 04, 2008
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
Does the Chunghop RM 133E universal remote work with Sony Wega? I have a Sony Wega model KV-BZ213N50 and the Chunghop codes listing doesn't have Sony in their list.
041, 049, 005, 094, 106, 148, 237, 238, 239, 240
these are the codes I could find for Sony with your Chunghop remote control. I hope this helps!
Aug 20, 2011 | Televison & Video
I need to find a remote control for this TV? can some one help me pls! TV model KLV-32U300A and remote control model: RM-GA009, my email robin uk_GB@hotmail.com thanks and appreciated!
The Sony RM-YD002, RM-YD005 and RM-YD007 models are purported to work with all Bravia LCD TV sets. There are a number of these listed on eBay with prices starting at about US$10. If, as I surmise, you are located in the United Kingdom, you will also have to pay international shipping. This is still much better than the $80+ Sony probably asked for exact replacements (a search of their global web site for your model came up null).
Feb 08, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
I have a Trinitron KV27FS16 with a stuck PIP. I do not have original remote. I do not have manuals. Only have access to on screen menu
Hello
To access all parameters of your Sony TV, you must have its original remote control. If you haven't one, get it from Sony authorised service center. The number of remote control for KV-32FS120 is [ RM-Y195].
OK.
Jan 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote contoller of sony trintion wega 21 inches doesn't work even with new sony batteries
you might have to open it up check for any cracks in the chip and if ur soldiering skills are good soder it up
Oct 25, 2009 | Sony RM-Y180 Remote Control
TRINITRON XBR/ADVANCED 2 TUNER PIP Model KV32XBR45 Manufactured 1995
WELL I need some more information so I be able to assist you, first , it could be that the REMOTE CONTROL is not that came with the TV originally , and since all SONY remote control have the same basic codes ,it could be that the remote doesnt have this specific feature. I did some research base on the model of this TV , the original remote control model num. is RM-Y127 and
not RM-Y153 , maybe thats why it doesnt have the PIP feature. hope this info been helpful
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Televison & Video Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
