Question about LG Studioworks 700S 17" CRT Monitor
Dark colors Hi There! I bought a LG CRT monitor and it displays dark colors. How can I make it lighter? P.S. The brightness and contrast are 100 on the OSD.
  • 65 Answers
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
Posted on Nov 17, 2008
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Princeton VF723 monitor is getting very dark. Brightness control is up full. Do I need a new monitor or maybe just a new driver?
i would start looking for a nice 22" LCD monitor.
Your monitor was manufactured by phillips and this symptom is very common. The crt gun gets week and has low emissions. The vid card driver has very lillte to do with the brightness control. However if your card is one of the newer nvidia or ati cards there are control ls in the software for brightness. color temp. contrast ect. Doesn't hurt to check but my guess is monitor.
Check out a LG or view-sonic for new ones.
Apr 07, 2011 | Princeton Digital VF 723 17 in.CRT...
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
It looks very dark
The fault could be a faulty inverter board or a faulty CCFD lamp.
The inverter supplies high voltage to the CCFL lamp. The CCFL lamp is a mini fluro lamp and can dim with age.
Check LCD Parts for service, parts and DIY info - click on this link to their WEB site : -
www.lcdparts.net
Oct 06, 2009 | LG Flatron Ez T910BU 19" CRT Monitor
Moniter Display Problem.
Either cable contacts inside your monitor is not proper or the data cable is faulty. Monitor repair is required.
Dec 13, 2008 | LG Studioworks 563N 15" CRT Monitor
Dark display
dear mr faolib
the solution is to install a 250 ohm resistor between G1 and ground on the socket ,,,but you may change it more or less than 250 ohm . it well be lighter and you you can adjusted normally from controll panel
ghassan eid
00962776936354
gasan_eid@yahoo.com
Oct 20, 2008 | LG Studioworks 700S 17" CRT Monitor
LG Flatron E700SH
Hi its not problem it is just setting difference
Try this one
go to menu setting and increase TEMPERATURE to 8300 or between 8300 to 9300
this will help you to solve your problem
thanks and regards
Teknas
Aug 17, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
LG Studioworks 700E
seems flyback problem ,leave it to the repairman...
Aug 19, 2006 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
227 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
