Question about Toshiba Satellite A135-S4527 Notebook
Prior to today my laptop was working fine (wirelessly). I have just switched on now & there is a message to say that 'A Network cable is unplugged'. Now, being new to all this internet thing I dont know what that means, especially since i have not touched anything or unplugged any cable to any network. Can you help me as to what has gone wrong between today & yesterday (other thatn the clocks going back).
  • jebbeskotte Oct 27, 2008
    I have the same problem but it keeps asking me about my wireless communication switch (which says off) How do I turn it back on? I was not having any problems then it says I am not connected. I have been using wireless on the laptop for the past month.
All it means is you haven't put a ethernet cord connecting your laptop to your router. Since you are using wireless it is not a problem.
Posted on Oct 27, 2008
  • 156 Answers
It is the status of LAN card.If u not use that just disable that LAN card from My Network Places.
Posted on Oct 26, 2008
How can I turn on the wireless capability on my Asus G60VX laptop? the switch on the front left is on and still nothing. trouble shooting says wireless capability is turned off. it was working fine untill...
I can figure out that your laptop runs Windows Vista. Go to Control panel, then Network and Sharing centre and then go to Manage Network Connections and see if the Wireless Network Connections icon is disabled, make sure it is enabled and not connected. Try disabling and enabling it again. If still no go, try to manually turn off the wireless switch and turn it back ON. Check the light status (if any), confirm the error message too. If still, it seems not to be working, then the internal switching might have gone bad. You need to get the laptop serviced.
Regards,
Arvind
May 25, 2010 | ASUS Operating Frequency 2.4 - 2.5 GHz...
Wireless no longer accesses router
OK try this go to that PC, go START>>RUN>>service.msc (enter) Now when services window comes up, scroll down to DHCP, set to OFF & Disable, reboot, now try again. Sometimes just a Turn it ALL OFF, and ON again and most often it will sort itself out., IF it was working OK prior. You could always run the "Connect to internet Wizard" again, and do that. Also go into router and ensure that DHCP, is set to ON in the Router. Sometimes, a simple re-setup will get it all working again too.
Apr 01, 2010 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
Laptop shows 'A network cable has been unplugged" every 5 seconds
The Cable may have loose connect to the RJ45 jack get another good cable and it will work. Also make sure that the clip on the RJ45 jack as not broken and make it click when you connect the jack to the Network port on your laptop
Dec 29, 2009 | Toshiba Satellite A75-S206 Notebook
Wireless Adapter/Switch/Connection Issues
Check the setting in "Acer ePM" (Power Management) under "Start" "All Programs" it sounds like the computers put it to sleep.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Constantly get a message saying a network cable is unplugged. Nothing is unplugged and my connection works fine on my laptop but witht he dlink adapter on my desktop it get this message
the same connection i take it works when you plug in your laptop,but fails when you plug in the desktop.If yes the network card is bad.
good luck
Aug 26, 2009 | D-Link DFE-530TX+ Ethernet ED100W Network...
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
2wire wireless connection problem
Make sure that the wireless switch on your laptop is on. Click on view wireless network by right clicking on the network icon on your system tray. Locate the name of your modem ( SSID ) & enter the wireless encryption key ( WEP ) or password
Apr 08, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Cant connect to network
hi, there might be a chance that the wireless card is broken.
Apr 02, 2009 | HP Computers & Internet
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Laptop problems
Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Toshiba Satellite A135-S4527 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
