Question about Frigidaire StandardDepth Side-By-Side Energy Star Compliant Refrigerator Model GLHS67EE - PQ / PB / ...
Filtered water quit working on my Frididaire side by side
I have a Frididaire glhs67eeeq, and there is not water coming out anymore. Any suggestions. We have checked water supply and replaced filter. Also no water to the ice machine.
  • Angel Metcalf Aug 21, 2006
    Thanks for your help. It turned out to be a plugged line at the water main. After my hubby put a new valve it we had water with pressure yeah. However then the ice machine did not work. He used the blow dryer method on the freezer side and had to turn some screw on a valve in the back. YEAH!!! We have ice and water. Fixed for under 20 bucks. So we can not add this to the money pit. LOL. Thanks a million for your help. Angel
    President:
  • 878 Answers
Angelbaby, there is a couple things for you to check. Number one is to remove and reinsert the filter. I had one once where it was not exactly seated correctly and caused this problem. If that's not the case check to see that the water reservoir is not frozen. This will be behind the drawers on the refrigerator side. You can take a hair dryer and go lightly over it to melt the ice if it is in fact frozen. Finally in the back by the triple water valve is a diode on the valve harness. If this diode failed you will not get water or ice. Let's hope this is not the case and it's one of the first two senerios, Catriver...post back
Posted on Aug 21, 2006
Massage feature on handheld filtered showerhead doesn't massage anymore. replaced the filter only 2 of 3 pairs of jet nozzles have water coming out
The nozzles have probably become clogged with sediment over time. Soak shower head in CLR for 3 - 5 minutes to dissolve sediment. Run water. If nozzles still not free, repeat the CLR soak. If still not working then nozzle head probably needs replacing.
Sep 18, 2018 | Jet Home
Maytag refrigerator filtered water stopped running
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 26, 2012 | Refrigerators
We got 42303 iron and use filtered water but we still get bits of scale coming out of the base
I would suggest using distilled water, since something in the filtered water is producing the scale. If you switch to distilled, that should eliminate the scale.
Good luck, and hope this helps.
Nov 15, 2010 | Morphy Richards 42939 Iron
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fgs65
Sep 22, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
No filtered water
More than likely you need a new water valve in the rear. You can test this by going to the back of the fridge and taking off the rear panel then remove the water line going under the fridge to the bottom of the door. This works great if you can get help. Just have the other person pull on the hose going in the bottom of the freezer door to help dentify the right one. Once the correct line is removed from the valve, have your teamate push the water paddle in and see if any water comes out of the valve itself where the line was. GE water valves do go bad quite often.
Jan 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator quit working.
for what you are saying check your voltage check if your compressor or check if condenser working you need the fan to cool the compressor down
Apr 07, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
although you had waterto the bottom of door when disconnected, did you try to dispense water while unhooked andsee it flow??? because just unhooking it will allow the resivoir of stord water to flow out by gravity, giving false sense of water working., if indeed it did work the you have a frozen water lin within the freezer door itself, ait tricky to defrost. aside form unplugging unit and allow to thaw out, or pulling line form liner not going to be easy to thaw the line. if you indded still hear the "hum" after disconnectng water under door, then it soundsas if you have a bad water inlet valve located behind refrig where the water atteachges to the refric, no repairingthe valve it needs replacing
Nov 20, 2008 | Frigidaire FRS26R4A Side by Side...
Galaxy Side by Side Refrigerator water dispenser
Check the water valve in back of refrigerator and make sure it is working ok
Nov 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
No Ice
I've got one, and the bracket in the back that connects the motor to the long screw-crank in the floor of the ice tray broke in half, so no ice was getting pushed to the door to come out the front. Putting in a new bracket started ice coming out again.
Aug 21, 2006 | GALAXY Microsystems 25.4 cu. ft....
Can you remove a line from the back rear of the unit and see if water flows there? The solenoid valve should make a solid "click" when the water lever is pushed. Any debris in the valve filter screen? See if you can reach up or look inside to see if the water lever is actually pushing the door mounted switch in, may be able to press switch with your finger if you can reach it or with a pencil, etc.
Aug 20, 2006 | Frigidaire StandardDepth Side-By-Side...
Refrigerators Logo
94 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
