Question about Garden
Need to replace momentary switch on weedeater trimmer
How to take cowling off to replace kill switch
5 Suggested Answers
trippssmengi
  • 76 Answers
SOURCE: Troy Bilt 4-cycle trimmer won't stop!
Check all wire connections,where they connect to the switch- to the motor-and to each other sounds like a bad ground
Posted on Jan 03, 2009
panilling9
  • 284 Answers
SOURCE: Weedeater xt200 broken throttle lever
manddmower.com
part # will be 530038682
Posted on May 31, 2009
  • 240 Answers
SOURCE: how do iremove trimmer head weedeater fl20
It depends on your model. You can visit the PIVOTRIM website and they show how to install their head on most units which includes how to take your old one off. Their website is http://www.pivotrim.com
Otherwise you need to look at your operators manual or call the manufacturer.
Posted on Jun 14, 2009
rycgl
  • 1545 Answers
SOURCE: I need to replace fuel line in Weedeater trimmer.
Enter Weed Eater fuel lines in the search field for numerous results and if not, repost here.
Posted on Aug 08, 2010
I have a weedeater featherlight which is discontinued, but anyway where is the setscrews on the carb i need to tune it!
they are covered,if you need to tune it then you need to clean and rebuild the carb and replace gas lines,buy it all on ebay for less than 20 bucks,ethanol kills plastic,buy the whole carb,you cant adjust yours
Jul 26, 2015 | Garden
Weed trimmers
No just un plug to stop it but use insulator plyers or rubber gloves
Apr 26, 2014 | Ryobi Garden
Not getting any fire
Hello, W/D here.
Locate the kill switch on the front of the engine. It is a "momentary" switch that will return to it's original position when released. Sometimes they stick. When they do, the engine is stuck in the "off" position. Try working the switch. It may be the problem.
Best regards, --W/D--
Apr 12, 2011 | Craftsman Convertible 14" Gas Line Trimmer
I need to replace fuel line in Weedeater trimmer. How can I do it ?
Aug 07, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
My Ryodi Weedeater Has No Fire To Plug Put A New One In
The plug receives its fire from the coil module which is mounted next to the Flywheel. It will have to be checked. If the unit has a kill switch, the wiring to it needs to be checked too. The important thing about the coil module is that the pickup legs on it need to be about .012" from the magnets that are inside the edges of the flywheel. There's always the possibility the coil has failed, but they don't very often. Check the air gap as stated at the flywheel and make sure there are no bare or chafed wires to the kill switch going to ground somewhere.
Jul 18, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I am working on my Husqvarna 124 L line trimmer. It suddenly stopped running. I know a few things about fixing engines and because of the way that immediately stopped, I figured that it was an electrical...
Kinda backwards than normal operation I see string trimmers. It could a weird setup. Check the kill operation with an ohm meter. If it is a closed circuit in run and open in kill position you may electrical connection problem in the wiring.
But normally you ground the magneto to kill the spark. By leaving the wires off at coil you should spark and not when you ground it.
Post an comment back when you out what is going here as I haven't seen this before. This might explain some reports I seen about customers receiving electrical from some Husqvarna trimmers.
Jun 10, 2010 | Husqvarna Garden
I was using my weedeater yesterday when it killed on me, now i can't get it started. I have checked the spark plug and changed the gas ect. any suggestions on what is going on?
well, my 125l is the biggest peice of **** I ever owned... from the time I bought it, It has been nothing but a headache. By the time I get the damn thing started, I am not able to weedeat... I bought me a Stihl, Gosh, sems like I have died and went to Heaven.
Jul 18, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Dec 17, 2008 | Troy Bilt Tb70ss Gas Trimmer
Weedeater or trimmer
sounds like the carb is still not right or the unit is low on compression - you need 90 lbs min
Oct 12, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
