Not all the Keys to my keyboard are working
I checked to make sure the drivers are up to date, Ive tried reseting the system a few times. Nothing seems to help. My Audio Player Controls are not responding to anything. If someone can notify me at Ryd66@yahoo.com with any suggestions i would greatly apprieciate any suggestions
  • Robert Ryding
    Robert Ryding Oct 29, 2008
    Thankyou, I found the problem minutes after i put the question up, My computer was updating itself and it had shut down all extra stuff to do so. leaving me with basic stuff
  • 47 Answers
Well happy to help u. looks like u r using a multimedia key board and the keys r special so u need drivers for that u can download it from ur product site. or may be the keyboard could be faulty. so plz try a another keyboard. and ur problem could be solved.pleasure to help u .
Posted on Oct 26, 2008
My at symbol and others do not work. how can I fix this please?
Catherine, Try compressed air to blow dust and debris from key board, try a system restore to an earlier date, you could also try re installing key board/driver, you may also have faulty key board and need to replace..
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Some Keyboard Keys not working
Not all keys on keyboard work
Some of my keyboard keys aren working
Aug 07, 2016 | Logitech Computers & Internet
Aspire one d255 volume moves itself
check your keyboard make sure they are all up and not sitting lower than all the other keys if it is you may need a new keyboard.
Apr 08, 2017 | Acer Aspire One D255 Netbook
Spacebar key and right arrow key of my MX duo keyboard was not working.
First: Have you spilled any liquids on the keyboard? If so, you may not be able to fix this.
But try a few things...
1) Get an air canister, compressor or vacuum with a nozzle. Try and ****/blow any grit and grime from under the keys.
2) Carefully remove the spacebar and arrow keys using a small flathead screwdriver. Slide the blade of the screwdriver under the edge of the key and lift it up. Be gentle, as the small mechanisms holding the keys in place can break. Once the keys are removed, clean out any dust or grime using a lint-free cloth.
3) If nothing works, go get a new keyboard...you can get a nice one for under 30 buckaroos.
Mar 10, 2011 | Computers & Internet
Some of the keys of my keyboard not working. LIke r, y u, cap lock, 2, 4,0 etc. I reinstalled the software, run norton antivirus etc but still the same problem. Even tried to restore the computer to...
The most common problem when faced with a non-working keyboard is an improper connection. Try reconnecting your keyboard, restart your computer and see if that fixes it.
2. Turn off the system. Unplug the keyboard connect and inspect for any bent or broken pins. If the pins are bent, then it is possible to gently straighten them using the tip of a ball point pen or mechanical pencil. If the pins are broken, then replacement of the keyboard may be necessary.
3. Try updating the device driver. Visit the manufactures web site for the latest driver available for your keyboard make and model.
4. While at the manufactures web site. See if there are software patches or updates available for your keyboard. If there are, go ahead and install them as well as the updated driver.
5. If you are using a multi-media type keyboard, be sure to delete the software before installing any new drivers for this type of keyboard. Install the updated driver for the manufactures web site, then re-install the keyboard software. If any software updates or patches are available for your multi-media keyboard, install them at this time. Delete the keyboard software by using Add/Remove Programs (Start>> Control Panel>> Add/Remove Programs). If you receive a prompt asking if you would like to remove all shared files, answer "No to all". Then click OK.
Jan 26, 2010 | Sony VAIO VGP-WKB1 Keyboard
Setting clock and date on logitech mx3200 wireless keyboard - need instructions
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Aug 18, 2009 | Logitech Computers & Internet
Keyboard Multimedia Keys?
try going to the start menu and then run type in msconfig in the box and click the last tab at the top labeled startup check and see if the device description is in that list if so make sure it starts running on startup by checking the appropriate box. restart and valla.....
Hope this fix ya
dont forget to rate
Ryan
Nov 18, 2008 | Computers & Internet
F Keys Do Not Work
try useing a usb keyboard this will work
Oct 28, 2008 | AMD Athlon 64 X2 4200+, 2.2 GHz...
Every once in a while my keyboard doesn't work
The keyboard driver is part of the system driver pack. Ensure your drivers from Toshiba are up to date.
Jul 02, 2017 | Toshiba Satellite R15-829 Tablet PC
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
