Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System
High pitched whine from Kenmore top mount refigerator Model 106.6118
aborcass
  • 2651 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Posted on Feb 24, 2008
  • 1314 Answers
SOURCE: Dryer Squeaks
ok your having the begings of a rear bearing problem now let me tell you whats happing if you pull the dryer out and look about at the middle of where the drum is at the back then you will see a silver small rectangle peice in the middle of that is what looks like a small finger with a steel ball under it on the little ledge there should be a little pile of black dust the little finger is making the little ball cut into the back of the rear bearing but the rear bearing is still good now get you a little can of spray lithem grease clean the dust off turn the dryer on and spray that little ball till its coated then every time you hear it squel repeat the proceadure untill one day it wont stop then we will have to change it and on that day you better have some help lol
Posted on Mar 31, 2008
SOURCE: Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Posted on Dec 11, 2008
vanni7
  • 163 Answers
SOURCE: Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Posted on Jan 03, 2009
danromarris
  • 101 Answers
SOURCE: Kenmore washer Model #16852 make high pitch sound while spinning.
Is the high pitched sound that you hear during the spin cycle or just all the time during the wash? If it's during the spin cycle it's probably your transmission and the only way to fix it is to replace the transmission. It's only going to get worse with time and soon enough it will just seize up on you and nothing will work. A transmission for a Kenmore runs anywhere between 150 to 250 dollars. 150 if you can find a refurbished one. You can find them at any appliance repair shop. Kenmore transmissions are fairly common as it's a big name. I hope this helps you and if you have any other questions or need help with installing it let me know. I can give you an easy step by step walk through on how to install it. It doesn't take too long. Good luck to you.
Posted on Jan 22, 2009
During spin cycle it makes a high pitch whining sound and sounds like a button is loose in the tub
does it have a burning smell? is it belt driven? rather than direct drive. belt are known to emit a whinning pitch sound at times. could be bearings going out. and sometimes a pc of metal opr material can get stuck between hub and shell and make weird sounds?
Nov 08, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Intertherm furnace model m3rl060abw blower makes high pitched whine when running. why? how can i fix it?
not familiar with that specific model, but if it's high pitched, it is likely the induced air blower causing it. sometimes it is possible to disassemble the motor and clean and lubricate it, but the repair that most service personell will do is to replace the motor. often it comes as an assembly which includes the motor and fan.it's the easiest, longest lasting, and quickest solution.
it is possible that it is the circulating blower with a seized bearing causing the whine. if so, the bearings (and shaft) can be replaced.
Jan 27, 2013 | Heating & Cooling
A high pitched whine, sounds like it needs oil? Does it - or grease somewhere?
No grease //but the pumps tend to make a high pitched sound when getting bad/I have seen them do that then the sound disappear but most likely the pump is bad or somthing in it..If you need more info please ask.......if i helped you please vote and good luck.
Feb 06, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Fan in top of the refrigerator is making a high pitched whine when running
The high pitched noise is likely a bearing on the fan motor going out. You should replace the motor soon as it may fail completely.
Oct 18, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
