Question about Sears Exercise & Fitness
I was walking on my treadmill (Health Rider Soft Strider LX) and the light was flickering in the room so I paused the machine, stopped walking and switched the pluges and now the treadmill will not turn on.
  • 4 Answers
You probably have either a bad plug or a bad outlet. try plugging it into a different wall.
Posted on Feb 18, 2012
2 Suggested Answers
  • 20 Answers
SOURCE: the belt has slowly moved
There are two allen bolt adjustments on the bottom left of the treadmill as you are facing it to get on. o adjust the side-to-side position, turn one one way and the other the other way.
Posted on Oct 26, 2010
I need a replacement key for my treadmill
Check the link below
http://www.ebay.com/itm/1-Treadmill-Safety-Key-PROFORM-WELSO-NORDIC-TRACK-HEALTH-RIDER-IMAGE-/251150799203
If you wish to get some more details about any treadmill ; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 07, 2016 | Exercise & Fitness
When walking on treadmill it brag every other few steps I take it will almost pause. do I need to buy lube for the walking deck ?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I can only assume you mean drag, not brag. That being said, it really sounds like your running belt needs to be tightened. I will attach a link with instructions on how to do this. The adjustment should be found at the rear of the machine. How to Tension Treadmill Walking Belt that Slips
Dec 23, 2015 | Exercise & Fitness
How do I tighten belt on health rider
Hi There,
Firstly take off the motor cover and check that the motor belt is not slipping when you use the treadmill. If it is not slipping turn the rear roller adjusting bolt 3/4 of a turn clockwise. Retest. If you have to turn it much more than another 1/2 a turn then the machine needs a tech to check over .
Sep 18, 2014 | HEALTHRIDER Exercise & Fitness
How do I unfold the health rider h75t
Guys ,
Try rewarding your body by feeding it isagenix
Warm regards
Isagenix Consultant
www.msranderson.isagenix.com
The Isagenix Wealth Creation solution
Cleanse for Life
The Isagenix Weight Loss Solution
The Official Site of Isagenix International
Jan 26, 2014 | HEALTHRIDER H75T Treadmill
Control panel shocks
This is a common occurrence as we enter the dry season. Static electricity will build up as you walk/run on your machine. There are many factors which make the problem more or less evident - the type of walking belt and deck, design of the treadmill, type of walking shoes, etc.
Some treadmills have a grounding wire from the console to the frame of the treadmill as well as a grounding wire from the rear roller to the frame of the treadmill. Check to see if these are in place, or have a qualified technician check this.
One common solution is simply to add a humidifier to the room where the treadmill is located. Raising the humidity will greatly reduce the static shock problem
Nov 30, 2013 | Endurance Exercise & Fitness
Should I buy a treadmill or an elliptical?
I suggest buying an elliptical machine because you can do alot more exercises with them and they take up little room. Treadmills take up a lot of room, use a lotof electricity and you can only run or walk on them.
Jul 09, 2012 | Exercise & Fitness
The belt has slowly moved all the way over to the right and is rubbing up against the right side. How do I adjust the belt back to the middle of the treadmill? It is a Health Rider XL Soft Strider.
Oct 25, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
1-Error 2 keeps appearing on the screen 2-It
3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back to ERROR 1. Check the connection that leads from the motor the board with a mutli-meter insert them in the motor connectors and start the unit their should be a D C voltage out if not the board is bad and need to be replaced. If not reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the speed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph if no belt movement you for the most part will have worn brushes or open windings in the motor. Also I check the belt and since the majority of the problems ( 75 to 85% of time)start with lack of maintenance ( lubrication)thus causing added expense to the consumer.
Here is a typical guide for maintenance their may be a slight variation from different manufacturers all in all the same.
NOTE: To prevent electrical shock, be certain the treadmill is turned off and unplugged from the electrical outlet before performing any cleaning or routine maintenance. TREADBELT LUBRICATION For average use of your treadmill, factory recommends you lubricate under the treadbelt once per year. For heavy use, which is more than 10 hours per week, factory recommendation is lubricating every six months. . LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes. CLEANING DAILY: Perspiration should be wiped from the control console and treadmill surfaces after your workout. CLEANING WEEKLY: You should wipe down your treadmill once a week with a water dampened, soft cloth. Be careful not to get excessive moisture between the edge of the digital display panel and the console, as this might create an electrical hazard or cause the electronics to fail. IMPORTANT: DO NOT CLEAN OR WIPE THE TOP OF THE DECK UNDER THE CENTER OF THE RUNNING BELT. MONTHLY: Clean dust and dirt that might accumulate under and behind your treadmill once a month. Small rubber particles from the soles of walking shoes will accumulate alongside the belt and also behind the unit
May 18, 2010 | Exercise & Fitness
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Exercise & Fitness Logo
113 people viewed this question
Top Sears Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Sears Exercise and Fitnes Expert? Answer questions, earn points and help others
