Question about Phoenix Digital PD-VIVID 7 in. Car Monitor
Phoenix digital 5.6 tft monitor pd-179
I would like to know where i can get a new din plug for this monitor.
Looking for the plug in harness for a Nitro bmwx 33.2 where can I get 8th?
BMWx-33.2W :: 3.2" Widescreen Head Units, Digital TFT ...
www.nitroelectronics.com > Car Electronics > Car Video
HEAD UNITS Digital TFT One DIN Widescreen 3.2" BMWX-33.2 By Nitro. ... Camera Input (without camera); 4 Channel High Power Output; Plug-In Harness ...
One Din with Monitor - NITRO-AUDIO
www.nitro-audio.com/one-din-with-monitor.html
BMWX-3.2 3.2" Digital TFT One DIN Widescreen/Touch Screen ... Plug-In Harness • NTSC/PAL System Compatible ... BMWX-33.2W 3.2" Digital TFT One DIN ...
NITRO BMWX 5393BT Car Stereo Bench test - YouTube
? 1:36
https://www.youtube.com/watch?v=PHjoXd55mTo
Mar 11, 2013 - Uploaded by colorado4wheeling
Looking online i couldnt find anything about this unit , except for the stock ... Looking at the devic ...
Dec 09, 2015 | Cars & Trucks
Nitro car stereo manuals
Need settings code for an Nitro BMWX-4756 300Watt 7" Touch Screen Monitor In Dash Din DVD CD AM FM for the gps, settings it's a 4 digit code to change GPS settings
May 01, 2015 | Nitro Bmw-4741t In-dash Touch Screen...
My computers sound driver
1 . Right-click on My Computer and click on properties
2. Under the Device manager tab select on the Device manager
3. Now double click on the System Devices → Right click on the Microsoft UAA Bus driver for High definition audio and disable it
4. Now Uninstall it
5. now again install the driver for the Audio Driver
6. Reboot and Enjoy
Read more: http://comsguru.blogspot.com/2009/11/install-realtek-hd-audio-driver-failure.html#ixzz0nMLSq8px
May 06, 2010 | Phoenix Digital PD-174 7.2 in. Car Monitor
Amp on "protect" mode
Hi, what you need to do is unplug all the connections to the amp. The amp goes into protection when the circuitry over heats.\
First decrease all your gains to minimal volume.
Connect your 12+V, remote, and ground.
See if the protection light comes on then.
Next plug in your RCA cables.
Check protection light.
Then plug in your subwoofer cables.
See if you are still in protect mode.
Hopefully everything works alright again.
Just slowly increase the gain to see what the cut-off is. Make sure you aren't dropping the ohmage too low on the amplifier. Check manual for correct wiring and such.
Feb 08, 2009 | Phoenix Digital PD-394 Car Amp
New new cables and monitor
IN A **** SHOP AT 15 N CALIFORNIA IN CHI
Jun 08, 2008 | Phoenix Gold PD-MOTOR7 Car Video Player
Phoenix digital pd234
First of all did the set get wet? If so, It needs the boards washed Immediately! Spray boards with windex soak em up. Need to remove all salt deposits and minerals or the boards traces will rot.Then rinse with distilled water let dry Then you could save this set. check this site They rebuild assorted stuff cheap. www.irionstvshop.com
Feb 23, 2008 | Phoenix Digital PD-VIVID 7 in. Car Monitor
VIDEO CABLE & MOUNTING HARDWARE F/ PD-174
Hi Coleman,
Nothing really special needed unless you get it running and you have lines or snow on the screen. You can use a the PS2's A/V cable, just run it on the opposite side of the car from the power. Also, you will probably need more length than the average PS2 A/V cable has, so Splice in some length. As far as mounting, Most of the time, I fashion an adapter to connect into the bracing for the dome lamp. You might get lucky and find a Bracket made for the Expedition. If you do not like the postition of the Dome lamp, thge roof of the expedition should have ribs. You can make some cross beams to span betweent he Ribs and allow for mounting your Monitor.
Nov 06, 2007 | Phoenix Digital PD-174 7.2 in. Car Monitor
Phoenix Digital PD-VIVID 7 in. Car Monitor Logo
71 people viewed this question
Top Phoenix Digital Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phoenix Digital Car Audio and Video Expert? Answer questions, earn points and help others
