Question about Dell Inspiron 600m 1.6GHz Pentium M Notebook (162891033) PC Notebook
Why doesn't my Dell 600m recognize a PATA IDE SSD?
Yes, it's a few years old but runs well, especially programs that won't run in Vista or 7. Currently have a 40G HDD and was looking to install a SSD as it has no moving parts and would hopefully run a little cooler and faster. The PC recognizes the SSD via USB bridge - the SSD is formatted and active - but BIOS doesn't. Only possible boot choices are internal HDD (does not see two when connected via USB), CD/DVD or USB device. Baffled. Any suggestions? I know it's been done, but can't find any instructions on how to alter CMOS or BIOS.
  • 28 Answers
SOURCE: Dell 9200 desktop. New motherboard,
1st question... does the cd-rw recognizes (read) standard cd's... if so it just a driver prob.. if not then find the incidence of the device in the Device manager, delete it and restart thecomputer. Also.. you may go to the dell website and re install any available driver. One last measure... rare but sometimes the connection are loose and not seated properly..
Turn off the computer, unplug, open case push on ALL the connectors and are seated..(including memory)....
If all that fails then its a bad drive... also rare but a lot more common with mass produced comp. It may still be under warranty and at worst ;you may have to pay ship and handling.
pleas email and notify fixya if this helps.
Posted on Mar 15, 2008
Vivektj
  • 55 Answers
SOURCE: dell e1505 is not recognized
You mentioned that the “Devicemanager always shows the DVD ROM in error state”, by this I’m assuming that ithas a yellow exclamation on it.
Follow the steps below todelete the UpperFilters and LowerFilters values with Registry Editor, this willmost likely fix you issue.
"Click the Start button,click Run."
"In the Open box, typeRegedit, and then click OK."
Click the plus sign (+) nextto HKEY_LOCAL_MACHINE.
"  NOTE:When you click the plus sign (+) next to a folder, it will expand displayingthe folders it contains in the left-hand pane of the Registry Editor. When afolder is highlighted, its contents will be displayed in the right-hand pane ofthe Registry Editor. "
Click the plus sign (+) nextto SYSTEM.
Click the plus sign (+) nextto CurrentControlSet.
Click the plus sign (+) nextto Control.
Click the plus sign (+) nextto Class.
Click{4D36E965-E325-11CE-BFC1-08002BE10318}.
"On the right hand sideof the window, click UpperFilters (if available)."
Click Edit on the menu bar.
"Click Delete, and thenclick OK."
"On the right-hand sideof the window, click LowerFilters (if available)."."
"Click File, and thenclick Exit."
Restart the computer normally.
One these steps are done youwill notice that the yellow exclamation has disappeared. And the drive will belisted in “My Computer”, is you still have problems with playing the video, theissue is with the DVD MPEG2 Codec. Download and install Klite Codec pack from http://www.free-codecs.com/download_soft.php?d=5075&s=775. This will definitely fix any playback issues.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Posted on Mar 25, 2009
  • 13 Answers
SOURCE: Can I upgrade my dell latitude C600 40gig primary
Yes you can.
Here is how to do it-- http://support.dell.com/support/edocs/systems/latd600/sm/hdd.htm
Posted on Jul 17, 2009
  • 3940 Answers
SOURCE: Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Posted on Sep 11, 2011
  • 59 Answers
SOURCE: I have a Dell Inspiron 8600 which is running windows xp pro. I have 2 Gigs of memory, the computer runs ok, but I'm receiving info from scans that my HDD Pata is about to go,I'd like to change
Well, you will want to open up the side of your computer and see if there are SATA ports on the motherboard. They look like this:
Though they may not be blue.
If there are SATA ports on your board, you are in good shape. Just buy any SATA hard drive (SATA2 and SATA3 are backwards compatible) and connect it with the SATA connector and a SATA power connector from the power supply. Don't be afraid, these can only plug in one way without forcing them and only SATA plugs will fit.
After that, there are a variety of drive cloning programs you can use to clone your current hard drive onto another so that you don't lose anything.
If you don't have SATA plugs on your motherboard, it is easily remedied. You can buy a PCI SATA card for quite a reasonable price like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816124024
You will also probably need a small adapter like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189121
To convert a molex plug into a SATA power plug.
After you plug in the card and the new hard drive, run the driver CD for the SATA add-in card and then run a cloning program.
Posted on Oct 25, 2012
Dell precision 530 bios ssd
This is a little bit long shot, but check also if there is an updated firmware for the SSD (you will need access to another machine in order to upgrade it). I will look up if I find either a bios for the Dell that is working or another solution
Mar 23, 2014 | Computers & Internet
Dell Inspiron 6400 won't detect SSD Drive
I think you were on the right track, the Dell Forums, if they have done it successfully , ask they how. I would only be covering ground you have already covered.
May 17, 2013 | Dell Inspiron Computers & Internet
Oct 25, 2012 | Dell Inspiron 8600 Notebook
I have an asrock 775vm8 motherboard. Can I install a ssd drive?
Yes, your motherboard should have 2 SATA ports, however, the SSD won't perform as fast as it could in a newer motherboard. You'll also most likely require a power adapter (molex to sata).
Jan 13, 2012 | Computers & Internet
Sep 11, 2011 | Dell Inspiron 600M Notebook
Hi, I have destop[ dell pentium R 4 cpu 3 GHz 1.99 GB of ram and 40 GB rom . I want to now if can change the hard disk and put another of 160 GB. tanks you carlos.
A) If you have the Restoration Disk (CD), or a full installation disk of the Windows operating system, the answer is yes.
B) If you have an image backup program, such as Norton Ghost, Acronis True Image, or DriveImage XML, for example, the answer is yes.
The Windows operating system is copied over to the new harddrive.
It would be easier, and more cost effective to just install the 160GB harddrive as a Slave drive.
I don't know if your harddrive is an IDE (PATA) unit, or a SATA unit.
Here is more information on installing either an IDE harddrive, or a SATA harddrive, as a Slave drive in a desktop computer,
1) IDE {PATA} harddrive:
http://www.youtube.com/watch?v=4inX3nC6M1E
1A) http://www.youtube.com/watch?v=OMTOgt3UiB4
2) SATA harddrive:
http://www.youtube.com/watch?v=kCgFYNLzn18&NR=1
IDE, also known as PATA is the older style of technology.
SATA is the newer style.
(Parallel ATA
Serial ATA )
The beauty of SATA is not only the faster speed, but if you connect a SATA cable (Data cable) to ANY SATA connector on the motherboard, BIOS will find the device.
BIOS (Basic Input/Output System) will find the harddrive with the operating system on it, first.
Then it will recognize that you have a second SATA harddrive also.
(BIOS looks at both SATA harddrives.
When it finds the one with the operating system on it, BIOS will disregard the other SATA harddrive)
http://www.youtube.com/watch?v=ScqDZZeFK9I
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Dell Computers & Internet
I want to install a Super Talent IDE SSD drive in my Dell D610 but it won't recognize the drive.
Hmm, did the drive come with a few pins to be used? The pins, when attached correctly would make the SSD either slave or master... it could be that currently its set as slave, hence the BIOS would make some problems... have you tried that?
May 15, 2010 | Dell Latitude D610 Notebook
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
Will pata hard drive work on dell inspiron 600m? WD Scorpio Blue 160gb PATA drive
Yes, the Dell inspiron 600m uses the EIDE/PATA interface so your new drive should work fine.
Oct 04, 2009 | Computers & Internet
Computers & Internet Logo
218 people viewed this question
Alun Cox
