Question about Sony STRDH710
I have the Sony Str-dh710 and a Polk Audio PSW-10. My subwoofer isn't blown and it is on, not hot at all, and my reciever is working perfectly besides the fact that it isn't sending any subwoo
I also pulled off the front grid of the sub and pulled the cable out a bit and it makes a "Humming" noise. It has to be the reciever.
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: how to hook up a mp3 to a str-dh710
For just listening, anything with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the manual because they want you to purchase expensive accessories like docking stations.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Posted on Feb 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: On a sony str-dh710, is there any difference in
.. or read the manual about setup and getting multichannel audio from 2-channel sources. Calibration and Selecting a Sound Field.
Distance is linear spatial separation of two points. dB is audibility, sound pressure level, volume. The distance setting affects how the various channels are delayed to arrive at the primary listening position at the appropriate time to provide a plausible sound field. Simply making one or more speakers louder or softer will not affect the spatiality of it.
Posted on Apr 18, 2011
dunnbiker
  • 8546 Answers
SOURCE: my sony str-dh710 constanstantly goesinto
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 27, 2011
What type a fuse do I use for my Psw 125 power sub
Is this a Polk PSW 125? I'd contact Polk customer service.
Here is the manual http://www.polkaudio.com/Media/POLK/Product%20Manuals/PSW110_125_MN.pdf
There is some discussion here http://forum.polkaudio.com/discussion/77264/psw125-blown-fuse
A blown fuse indicates something wrong. I'd contact Polk.
Nov 17, 2015 | Audio Players & Recorders
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
PSW 125 Diagram Schematic
download with model number suport e-manual pdf
Aug 28, 2014 | Polk Audio Psw 300-watt 12" Powered...
Which amplifier plate can use for Polk Audio PSW 1000
call parts express tell them your problem and they do have a plate amplifier that will work actually it's a better amp with more power.
Jun 14, 2012 | Polk Audio PSW1000 Subwoofer
On a sony str-dh710, is there any difference in the amp. level between setting the distance levels and the db levels? Also using the Video 2 input on the front of the reciever I'm not able to get any...
Apr 18, 2011 | Sony STRDH710
Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Mar 26, 2010 | Polk Audio PSW10 Subwoofer
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
PSW 10 Not working
Your 2A 250v slow-blow fuse is blown, located under the back pannel. Mine just did the same thing. Problem is the problem with my PSW10 goes beyond the fuse. I have contacted Polk tech support to help me trouble shoot.
Sep 06, 2008 | Polk Audio PSW10 Subwoofer
Sony STRDH710 Logo
35 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
