Question about GE Energy Star WCVH6260F Front Load Washer
I have a GE Front Load Washer #WCVH626OFWW. I have a common problem that everyone else has experienced. After it rinses it will spin and then with 30 min left in the cycle it stops the timer continues to count down but nothing else happens. I have cleaned the filter, ordered a new pump and it still stops with 30 min left in cycle HELP PLEASE. Could it be the control panel is bad?
  • Steven Lawhorn Feb 18, 2012
    How do you run a diagnosis on a WCVH626OFWW
SOURCE: ge front load-
We had the same scenario, only our clothes were still very wet when it finally finished the cycle. To cure all three we cleaned the filter behind the front panel. It was badly plugged and it, and the water it was holding up, smelled foul. So far so good since.
Posted on Oct 10, 2007
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
SOURCE: Water will not drain. On the timer the door
bad pump impeller
Posted on Nov 02, 2009
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: We have a GE WCVH626OFWW
It will not spin because it is not draining the water...
Can you hear the pump running??
If not check for power to the pump, it may have gone bad...
If no power then the timer or circuit board probably went bad...
If running and not pumping... then check the hose for blockage....
or the impeller will sometimes just go to pieces and the pump will need to be replaced...
You will need to systematically work through the possibilities till you find the problem...
Problemswith a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 29, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
Problems with a washing machine not spinning or not draining are often interrelated..
heatman101
Apr 14, 2011 | GE Washing Machines
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
When washing a load the machine is not spinning.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 17, 2009 | GE Energy Star WCVH6260F Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
323 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
