Question about HP Pavilion dv9000z Notebook
Keys on laptop dirty underneath
How do I take the key off my laptop to clean under them. they are starting to stick and becoming a problem. I have an HP
  • 47 Answers
Sis u might want to get it cleaned from a service center. coz if u r not qualified u could end up with a faulty key board .and then end up paying more. there r tools and manuals to open laptops . and it won't cost u much.pleasure helping u and u can get a service center address on www.hp.com
Posted on Oct 26, 2008
I spilled soda onto the key pad. Three keys are sticking badly. How do I clean it?
Gently pry the key upward with a butter knife and clean underneath and the key with a 90%+ rubbing alcohol.
May 18, 2016 | Computers & Internet
Yahoo com
The keys may be damaged because of heavy usage, or the keys may just have accumulated dirt over time. What I do if a key isn't responding, is to carefully pull it off (CAREFULLY) and clean under the rubber part that presses down onto the circuit board. Also I clean the key itself, to make sure that when I put it back on, it does not stick, or is hard to press. To put it back on, if you look underneath the key, there is 2 tabs that you slide on first (The tricky bit) then just press the key down until the other two snap into place
Aug 10, 2014 | HEWLETT-PACKARD Compaq nc6120 Notebook
Delete key stopped working
One moment you are typing on your computer keyboard as usual, when suddenly a key sticks or does not produce a character on the screen.
Perhaps you have a group of keys that suddenly stop working.
Laptop and desktop keyboards alike can stop functioning due to a number of causes, most of which can be resolved by troubleshooting.
Knowing how to fix some keyboard keys that do not work can save you time, and save you the cost of buying a new keyboard.
Disconnect and reconnect your computer keyboard, then restart your computer.
Sometimes a poor connection can result in keys not working on your keyboard.
Update the device driver for your keyboard by going to the manufacturer's website of your keyboard, and then download and install the latest driver matching the brand and model number of your keyboard.
Disconnect your keyboard from your computer and inspect the pins in the keyboard connector if you have a PS/2 connector.
The PS/2 connector for your keyboard has six pins, which connect into a PS/2 port of your personal computer, to allow for communication to and from your keyboard.
Straighten any bent pins you may find, by gently using a ballpoint pen. You must replace your keyboard if you see broken pins.
Try testing your keys using a different application, such as another word processing program. Keys like the function keys on your keyboard labeled F1 through F12 may not work in one application but will work fine in another.
Clean Under Desktop Keys
Disconnect your standard desktop keyboard, then press down on a key not working.
Slip a car key or a flathead screwdriver underneath the key.
Twist the screwdriver or car key until the keyboard key pops off.
Use a damp cloth, moist cotton swabs or compressed air to remove dust, hair, and food crumbs under the key.
Use only water or rubbing alcohol to moisten the cloth and cotton swabs other cleaners can damage the plastic of your computer.
Position and press down on the key to snap it into place.
Repeat this for all of the keys to clean underneath them, if necessary.
Clean Under Laptop Keys
Turn your laptop off, then use a flathead screwdriver or knife under a key corner, prying the key off gently.
You will hear a snap as the key detaches.
Remove the key retainer remaining on your laptop using your knife or screwdriver under the corner, then popping it off with a gentle twist.
Remove the space bar by pulling it off after your insert the screwdriver or knife underneath the bar.
Clean underneath your laptop keys using cotton swabs or a soft cloth dampened with water or alcohol.
You can also use compressed air to remove dust, hair and other debris.
Replace your laptop keys by placing the key retainer into position.
If you cannot remember the position, copy another retainer's position by removing another key.
Insert the keypad into the retainer, then position the key over the retainer while pressing down on the key.
You should hear the key snap into place.
Place your laptop's space bar over the space bar slots, then snap it into place.
Apr 25, 2013 | Microsoft Outlook 2010
Keyboard on Inspiron Mini 10 is not working right. Had chocolate spilled on it. How do I clean it.
Because laptops are portable, people tend to eat and drink over them. They lay the laptops on soiled surfaces and stuff them in dirty book bags. With all of the wear, tear and abuse that a laptop sustains, it's no wonder that the keyboard can become quite dirty. When a keyboard becomes dirty, often times the actual keys won't work. It is commonplace to find dirt, debris and food under the keys of a laptop computer. This causes the keys to not engage properly, rendering them useless.
1.Run a duster over the keys of your Dell laptop. This will remove any dust or small bits of debris that are causing your laptop keys to get stuck and not work. Test your keys once you have dusted them.
2.Spray the laptop keyboard with condensed air. Hold the air nozzle (you will often insert a small plastic tube into the nozzle) about 4 inches from the keyboard. Spray liberally, and use a back-and-forth motion while you work. This will remove most pieces of debris that may be stuck under the keys. Test the keys to see if they now work.
3.Place the tip of your flat-head screwdriver underneath the right-hand side of the key that is not working. Lift up gently and the key will pop off.
4.Dip the tip of your Q-tip into the rubbing alcohol and rub around the area where the key meets the keyboard. This will remove any final bits of dirt and debris. Allow the area to air dry. Repeat on as many keys as needed.
5.Place the loose key directly over the space where it belongs. Note the small piece of rubber. Hold the center of the key directly above the rubber piece and press down. When you hear a small clicking sound, the key is secure.
Sep 09, 2011 | Dell Inspiron Mini 10 Notebook
Hi i have a gateway laptop ns51 series and im currently facing the problem of a not working function key/ fn key. i dont know what happened it just did not work. i badly need help please..
Check if the key is dirty, if still under warranty take the laptop to store. If not, try cleaning underneath the key. Thumb me up if I helped. :)
Jul 02, 2011 | Computers & Internet
Keys Sticking
no! you don't want to do that if you unscrew the back plate all the plastic suction cups with fall off and you will never be able to type on it, until you place the suction cups back what you want to do is get some WD-40 (the tool for fixing almost everything) or a can of pressurized air with a areosole top and aim it at the key or under it, press it and it will blow every piece of junk under the keys cleaning it.
Feb 09, 2010 | Logitech Wireless Access Duo Optical...
1 on the keyboard is stuck, can you help? Whenever I try to use my eee laptop for anything that requires typing, it runs itself off with 111111111 Please advise!
This could be due to the keys area being dirty and sticky. Make sure your laptop is powered off and disconnected from power then gently remove the "1" key by using a house key or paper clip. Be sure to get underneath the "1" key and pull up until the key pops off. With the "1" key removed, clean the area under the key with a lint-free cloth. Replace key when finished.
Jan 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
How do i unstick keys, for an acer aspire 5532? The "n" key is sticking, and I have to push hard to get it to work. Can i remove it, and then clean undereath it? Or do I have to work aroud it? I don't know...
on most models of laptops, you can remove the cover for the joints that hold on the LCD and underneath you'll find a few screws that can be removed to allow for the keyboard to be taken out, and I would subjest not using any strong cleaners for when you take the keyboard off. if the cleaner is too strong, it might break the keyboard and also remove the painted letters and numbers on the keys =P. when cleaning the board, I recommend rubbing alcohol and a thin cloth to get under the keys. The reason being that the alcohol evaporates within 40 seconds to 80 seconds after application thus keeping the logic unit from becoming wet. That way you'll be back in business not long after you finish cleaning.
hope that helped, good luck
Dec 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
My mother has a toshiba satelite a200 series and i was wondering how to properly clean under the keys, and was wondering what to do about my 'g' letter and my 'left' key , the 'left' key doesn't work...
You can pry the keys off the keyboard by gently lifting with a fingernail, or you can use a compressed air canister and a specific "T" stick with cottoned ends which slides underneath the keys.
The LEFT key has probably some dirt in the central contact, and you'll have to remove the key and clean underneath. Same goes for the G key, which has something sticky underneath. You can remove almost all kinds of sticky dirt by washing the key with WD-40 lubricant and drying with a non-lint paper tissue.
Detailed key removal and reinstall instructions may be found e.g. on eBay looking for "spare key tops" or "spare keys".
Oct 28, 2009 | Toshiba Satellite A200-0ET00X Notebook
Keys are sticking the keyboard. Can i clean underneath the keys?
Depending upon how sticky the keys are, it might be easier to buy a cheap replacement keyboard.  Trust me, it takes a whole lot of patience and a steady hand to take apart the keyboard key by key and then put it back together.
Mar 09, 2009 | Toshiba Computers & Internet
HP Pavilion dv9000z Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
