Question about Cfm Heating & Cooling
I Have a 6kw Changhong Air Conditioner. There is a "F3" error code Flashing?? PLEASE HELP!!! Its bloody hot today!!!
Ive tried power cycling numerous times, have refered to the user manual but there is no info in that.???? out of ideas now... please help!!
Hi,Ive been trying to set my icf-cd2000 clock radio,I downloaded info,It is so small I cant read it.(ive tried to make it larger on photo copier) but it only blurs ,can I buy a manual please,Or do you have...
Setting the Local Time
  1. Press WORLD/LOCAL to display "LOCAL".
  2. Hold downl CLOCK until you hear a beep.
  3. Press TUNE/SCAN TIME SET + or - to set the hour.
  4. Press CLOCK to enter the hour.
  5. Press TUNE/SCAN TIME SET + or - to set the minute, and then press CLOCK. Two beeps sound to confirm the setting.
Setting the WORLD Time
  1. Press WORLD/LOCAL to display "WORLD".
  3. Press TUNE/SCAN TIME SET + or - to set the desired hour and press CLOCK. Two beeps sound to confirm the setting.
If you need any more help, feel free to ask.
Mar 08, 2011 | Sony ICF-CD2000 Clock Radio
I have purchased a junior micam camera model POCP101. Im having problems trying to download my pictures on the computer. Ive restarted my computer and ive installed and uninstalled it so many times and...
I have helped some users with the same problem.
I have uploaded the contents of the installation CD for users to download, since there is no website to do so.
Uninstall the previous installation, and ensure the camera is NOT connected to the computer while installing the software.
Use the application (photo impression included in the install CD) to pull the photos from the camera.
You can download the install CD here (188.81Mb): http://depositfiles.com/files/qmc5ykx6p
If you just after the user manual, I have uploaded that here (2.6Mb): http://www.filejumbo.com/Download/26D632AAF285B1D0
Hope this helps!
Dec 25, 2010 | Cameras
My hotpoint wma74 front load washer makes a very loud thumping noise on the spin cycle ive got a feeling it could be the dampers but would like some more info please, ive run a the cycle empty and there...
It does sound as if at least one of your dampers are gone. Unplud the appliance from the wall, take the back cover off and see if there is any movement when you try shift the drum. If there is a lot of play on one side, that damper is likely gone.
Dec 12, 2010 | Hotpoint WMA74 Front Load Washer
My Miele Touchtronic T 9800 Dryer progrma works but when the dryer has ocmpleted its cycle, the cloths are still damp and not dry.. .I have to run the cycle several times to even get near dry cloths. what...
Hi dear.Try this,that should help you to solve the problem.If you need to download the user manual please click the link below.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T9802_us.pdf
Problem:The laundry is still wet. The program runs too long.
Solution:The air flow is insufficient. Check the lint filter, air intake and vent for obstructions(REFER USER MANUAL)
Aug 25, 2010 | Miele T9800 Electric Dryer
I have purchased a house with the single door dishwasher and it takes forever to wash - about two hours - what could be the problem?
Check your program settings. If wash quality is good, it's OK. Check your inlet water has sufficient pressure! Refer user manual
Apr 07, 2010 | Fisher and Paykel DS603SS Stainless Steel...
When i plug in my wii the color is like black and white pretty much, ive tried plugging in the cords every way but it doesnt work..the tv color works just fine and the other game consoles ive plugged in...
  • Is this your first time hooking up the Wii console or have you moved it to another TV or VCR? If so, please refer to your manual to review the step-by-step connection guide. Our experience shows that the majority of these issues can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
  • If you have verified the connection is correct, and are still receiving a blank white or blank dark screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call Nintendo Support for repair options. 1-800-895-1672
    If you do not have a manual for reference, here is the set up info online: http://www.nintendo.com/consumer/systems/wii/en_na/setupAV.jsp
    Good luck! Hope this helps! :)
  • Sep 13, 2008 | Video Game Consoles & Games
    Acer Keeps restarting
    You have to reinstall your operating system. There is no other option. Bcoz every time the operating system try to operate hardware it receive wrong info from the hardware drivers. Contact me again for more info
    Mar 31, 2008 | Acer Aspire 5100 Notebook
    Heating & Cooling Logo
    95 people viewed this question
    Top Cfm Heating & Cooling Experts
    Dan Webster
    Dan Webster
    David Payne
    David Payne
    Brett Duxbury
    Brett Duxbury
    Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
