Question about Hotpoint Aquarius WF210 Front Load Washer
Washing machine door will not open
The door to my washing machine is stuck and will not open after the wash cycle is complete. The clothes are inside. What should I do?
  • Anonymous Oct 26, 2008
    on a Frigidaire machine thou.
  • 958 Answers
Remove the front kick panel. feel at the back of the door switch, there is a plastic thing with a ring at the bottom, pull this down and you can hear a click at the door switch and you can open it now. that is the manual door opener. make sure there are no more water inside or you'll make a mess.
tnx 4 using fixya,
drcool
Posted on Oct 26, 2008
I washed a batch of wool/hand wash cyle. The washer did not automatically complete, the door would not open.
Remove the wall plug and leave 15 minutes for it to reset. Then choose low speed spin cycle. Dry woollies flat.
Jan 25, 2017 | Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
I am washing clothes in a borrowed Kenmore washer. It's probably 10 years old. It stops short of completing the Rinse cycle and never makes it to the Spin cycle. The bowl will start filling up w/ water,...
This is a typical problem with the "lid switch" on the washer. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 26, 2011 | Kenmore Washing Machines
Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Dec 08, 2007 | Maytag MAH8700A Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
130 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
