Question about Cadence Exercise & Fitness
Belt is slipping on Weslo Cadence 2300 treadmill. Is there an adjustment to the belt?
2 Suggested Answers
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
The belt on my treadmill keeps slipping and i wanted to know how to stop it ...
hi,
You have to adjust the treadmill belt. Just watch the following video to do the same.
OK
Sep 01, 2011 | Treadmill Doctor Weslo Cadence Dx10...
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Nov 15, 2010 | Cadence Exercise & Fitness
Walking belt slows down to almost a stop when i get on it
I believe under the motor shroud on the circuit board their should be 2 pots 1 adjusts torque 2. adjusts speed try adjusting them and see if that take care of the problem if not. worse case it might be the drive motor.
Feb 27, 2010 | Cadence Weslo 4200 Treadmill Walking Belt
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
The walking belt slips to the left when walking
There are two allen bolts (one on each side) at the end of the machine. These bolts adjust the tension on the belt. If they are not adjusted evenly the beft will gradually shift of the more loose side.
Sep 29, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
