Question about Emerson EWF2703 27" TV
EWF2703 27" TV --won't turn on
Has power to fuse in board, fuse is good,(removed back of unit used vom to test for power) think board is bad.a few weeks before this, sound went away, then came back. is part available?-- and is cost less than new tv. only paid 180.00 for it. 2 1/2 yrs ago. realy like the set..... good picture ect. but should last longer than 2 yrs....... is this common problem with these? i'm an auto tech, have tools, know when not to screw with it if i'm not sure what to do or how to,(thats why i'm asking), is there a way to conferm if is board or what part of board is bad. i could replace board myself if had one. thanks for any help, hondadoc.
    President:
  • 3,130 Answers
A complete circuit board is available BUT would cost you more then a new set. These sets now a days are repaired down to the componet level and these sets have no user replaceable parts. If you have a capacitor checker then maybe you can find on that goes bad in these . there in the sweep supply or in the standby power supply, but if your not a trained electronic tech you should not be experimenting inside this thing. 2 to 3 years is about normal with these things. You can get one for about 100 or so if you looked around. it would probably cost you 125 or so to have a pro fix it. GGood Luck
Posted on Aug 20, 2006
2005 honda goldwing gl1800 audio
you must measure the power input with VOM, test for loose wires, or corroded and fix it. Otherwise you must sure if the controller is o.k,use testbench for test outside from the vehicle and see what happen.
God bless you
Jul 27, 2013 | Motorcycles
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
My toshiba RC-3910 tv turns on but 10 mins later it turns off and it wont turn back on why
hello!
it seems, like the problem of your TV is the power supply module, particularly 12v power supply I.C. chip.STRW6735 or similar. I've replaced few lately with similar problem TV. It might have a few bad electrolytic capacitors on the board, as well. Solution: if you are possess electronics technician skills and have all the necessary equipment and parts , you may do the job yourself. Otherwise, look for replacement power supply board, preferably at used boards distributors(shopjimmy.com or similar). I won't recommend to buy used on e-bay, unless it has been rebuilt. Or, remove the board and take it to local TV repair shop for rebuilding. This way you may save a few bucks.
Good luck,
Alex.
Mar 06, 2012 | Televison & Video
The power switch to move the drivers seat back and forth is broken. How can the seat be moved back? is there a manual way to move the seat if the electric motor has a short in it?
Remove the switch & test it with your VOM Meter
Then if it is no good ,get a new one at the dealers
parts counter or a used one at a salvage yard
Everyone needs to stop with the fuse maybes &
shorts
A short is not a constant thing, as the wires burn away
& then you have an open circuit.
You will only have a very few fuses ever blow ,in 50
years of driving. Replacing one won't do a thing
A short is of no concern at all ,unless you have 2 feet of
melted wiring harness in your vehicle.
Jun 11, 2011 | Dodge Avenger Cars & Trucks
Dryer won't work, keep blowing high limit fuse. I have cleaned out all of the blower and vent line and there is no obstructions. high limit thermostat test ok. any help
  • Power could be off- - Check the voltage at the outlet with the VOM.
  • Timer or thermostat could be bad -- Follow same tests as listed above.
  • Terminal block could be bad -- Use the VOM to check for voltage at the terminal block. Be very careful here, as the power needs to be on for this test. If you don't feel comfortable, call an experienced electrician.
  • Start switch could be bad -- Set the VOM to RX1 and remove one of the leads to the switch. Clip the probes to the switch's terminals. The reading should be infinity. Press the start button and the reading should change to zero. If not, the start switch is bad.
  • These, of course, are not everything that can go wrong with your dryer, but only the most common problems. When removing parts for replacement, I find keeping a notebook nearby to take notes on which wire goes where, to be a valuable assistant. Of course, when you take your faulty part to the appliance parts shop, make sure to have the make and model number for your dryer, just in case they need it. With that said, good luck and hopefully your dryer will be sound for a few more years.
    please rate or vote on these solution on how helpful.
    Dec 24, 2010 | Kenmore Dryers
    Panasonic ct-32sl13g blowing fuse by power supply
    You will need to remove the back of the TV. Don't worry, it's not that bad.
    There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
    Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
    Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
    Apr 15, 2009 | Panasonic CT-32SL13 32" TV
    Mitsubishi WS-55807 turns on but then powers back down after a few seconds
    Good Day;
    The fuses tell you that circuit has failed and was drawing too much current. No other test is needed.
    Good Luck, big Irish.
    Sep 04, 2008 | Mitsubishi WS-55807 TV
    Emerson EWF2703 27" TV Logo
    Top Emerson Televison & Video Experts
    matt martin
    matt martin
     Grubhead
    Grubhead
    Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
