Question about BenQ PE8720 DLP Projector
Benq pe8720 service manual - BenQ PE8720 DLP Projector
8720 Went out just prior to playing. Now will start up, go to benq logo then lamp goes off. on top of projector lamp light is red. repeat lamp does go on seems as bright as ever but shortly after benq logo goes off. By my recollection lamp is not beyond it's 2000 hour range.
Posted on Jul 29, 2014
The big cooling fan makes a lot of noise, - What do I do ?
Hello
It may be due to some friction in its bush bearings. Take it out from the unit. Peel off the emblem on its center part slighly up, put a drop of machine oil to the center shaft point exposed. This must resolve the problem of your cooling fan. Brush out all dust accumuated on its leaves, if any, before refit it into the projector.
If this does not resolve the problem, the fan should be repalced with same type and voltage ratings. All these details will bw marked on the fan. It can be bought from most of the electronic spare part shops at your town, or from the authorised service center for BenQ at your town. If any leaf has borken, the fan will make noise. If so, it shoud be repalced. OK.
Nov 10, 2011 | BenQ PE8720 DLP Projector
I need service manual of benq sc3211
http://www.benq.us/support/
go to the above site and look for the manual to download if available. if it is not available we are sorry because the company itself has no manuals for it.
Dec 24, 2010 | BenQ Televison & Video
BENQ 5000 SCANNER DRIVER FOR MAC OS?
BenQ does not make MAC OS drivers for this model scanner. Only Windows XP on down to 98 are provided.
Maybe you could run XP in BootCamp, Parallels, or VMWare Fusion on your Mac and use the scanner from the Windows OS...?
Good Luck!
Jan 23, 2010 | BenQ Scan to Web 5000U Flatbed Scanner
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
My benq projector keeps blowing lamps.
first, blow out any dust with canned air. dust keeps in the heat that the projector is trying to expell. next, don't buy cheap lamps from random websites. you get what you pay for. and make sure you have the correct lamp that the manufacturer states. also make sure there is sufficient space around the projector. the vents cannot be blocked. lastly, reset the settings to factory default. many times there is a low power/full power setting. the fans go on full on high power. there should be at least 2 fans. one for the lamp, one for the optical engine. may be one for the power supply. if the one near the lamp is not blowing much, replace it.
Nov 29, 2009 | BenQ PE8720 DLP Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Replacement of HD of BenQ Joybook 3000 PC Notebook
Here is the manual. I hope it helps
http://service.benq.com.hk/HKUploadFile/Book/Joybook3000(3000MU)M.pdf
G'luck
Oct 23, 2008 | BenQ Joybook 3000 Notebook
BenQ 8700 projector solution
Hi Rick
The upgrade is the same one used for the BenQ PE8720
Whoever told you this obviously did'nt know this.
You'll be needing Flashloader and the RS232 cable that came with the Projector.
It is absolutely cheeky of them to suggest that you should just use the Component input for all your applications on this Projector.
Make sure they understand that this was a top of the range Projector when you bought it and that it is not a good enough answer.
Apr 02, 2008 | BenQ PE8700 Multimedia Projector
Projector shutdown
your air filter of your projector is dirty, try cleaning it. tnx
Jan 30, 2008 | BenQ PB6100 Multimedia Projector
BenQ PE8720 DLP Projector Logo
351 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
