Question about Microsoft Xbox 360 Console
Connecting xbox 360 to laptop for xbox live. - Microsoft Xbox 360 Console
  • JadenYuki105 Jan 18, 2009
    I plug in my ethernet cable to my 360 and I go on the dashboard press join xbox live and it doesn't work because I don't know what an IP adress is
  • 23 Answers
(this is a solution that i gave someone who had a wireless router...you will also need to forward the same ports even if you have a wiredrouter...)
Ok... I have the best solution to this problem... Obviously you have wireless internet...so that means you have a wireless router... you need to login to thewireless router settings... usually it is192.168.1.1 that you type intoyour browser by default... if it is not192.168.1.1 in order to findyour router address you need to click on start.... run... type in cmd...then in the command prompt type in ipconfig/all... your router addresswill be the number next to default gateway... put that into your browserand login to the router... dont exit the command box just minimize itbecause you will need it later...if you have not changed the passwordits usually either password...admin.... or nothing at all.... once youare logged into your router you need to forward the open the ports foryour xbox 360 for it to be able to connect to xbox live with an openNAT... (meaning you can connect to everyone without problems) once youget to port range forwarding you are going to have to put in 6 ports forbest performance... name them all XBL or XboxLive... and forwardthese ports... 87-89 UDP.... 3073-3075 UDP..... 80-80 TCP... 88-88UDP...3074-3074 BOTH... and 53-53 BOTH... make sure they are enabled...find out what your start ip address is... i changed mine to192.168.1.200with a maximum number of users at 50... (this will come inhandy and i will tell you why later...) turn on your xbox 360 and go tonetwork settings and manually change your settings... so if you haveyour ip address range from 192.168.1.200 - 192.168.1.249 like me...change the ip address of your xbox 360 to 192.168.1.240 (the computersthat connect to your wireless router always take the low ip addresses...so setting your xbox 360 ip address to 192.168.1.240 will make it sothere arent any ip address conflicts...) remember the box i told youto minimize? you are going to have to input the numbers in the commandbox into the boxes in the xbox.... 255.255.255.0 for the subnetmask...default gateway for the gateway... enter in the dns settings...first one is primary... second one is secondary... save and you are donewith that... if you have your ethernet cord hooked up from your computerto your xbox 360 click on start... control panel... networkconnections...click and highlight the network bridge and your wirelessconnection...once you have them both highlighted... right click... andclick on bridge connections... and everything should work fine...
Posted on Jul 10, 2009
    Problem Solver:
  • 14 Answers
This site has all the info you need to connect your xbox 360 to a laptop and then wirelessly to live :) :
[url=http://howtoconnectwirelesslytoxboxlive.blogspot.com/]How to connect to xbox live wirelessly[/url]
Posted on Jan 09, 2009
3 Suggested Answers
thegoshem
  • 61 Answers
SOURCE: XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
Posted on Jun 16, 2009
  • 5 Answers
SOURCE: xbox 360 can't connect to "xbox live party" for me or my friend
make sure u both have gold and make sure ur network doesnt have strict security
Posted on Jul 31, 2009
Xbox 360
For xbox live you dont need to connect it to the laptop.
If you have a router you can go wireless if you have the xbox adaptor or you can use a ethernet cable fromt he router to the xbox, which is a faster connection.
If you want to connect to your laptop to play music ETC go to www.xbox.com/pcsetup to download the media centre extender, this will then connect the laptop to the xbox.
Hope this helps
alex
Feb 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Xbox live failed
This site has good information relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
Aug 19, 2008 | Microsoft Xbox 360 Console
Cannot connect to xbox live using a wireless laptop
Aug 11, 2008 | Microsoft Xbox 360 Console
I'm trying to connect to xbox live over a laptop but it wont let me connect! What's up?
This site has good guides relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
Jul 03, 2008 | Microsoft Xbox 360 Console
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Problem with streaming from my laptop to my xbox 360 wirelessly
Call microsoft for a solution, they will most likely know in a few minutes. Even though you get punjab from india.
Mar 02, 2008 | Microsoft Wireless Network Adapter Xbox...
Connecting to xbox live
I can make it work for you
Feb 11, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
182 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
