Question about Toshiba Qosmio G35-AV600 Notebook
Replace wifi card qosmio 35 - Toshiba Qosmio G35-AV600 Notebook
  • Toshiba Master
  • 5,660 Answers
1) All power removed. Remove the AC adapter (Charger) and Battery.
2) Remove the Keyboard Holder. This is the thin strip of plastic located above the Keyboard, and below the LCD Module.
There is a slot above the Keyboard Holder. Place a finger in the Slot, lift up the Keyboard Holder while unlatching.
3) Remove the Keyboard. For this procedure the Keyboard does not have to be entirely removed.
Just unlatched, Flipped over, and laid on the Palmrest Cover.
(The Keyboard Cable is still attached to the Keyboard)
There are 2 screws to remove before removing the Keyboard. One on the Left, and one on the Right. There is a release tab also. Top/Middle.
Press it in, then lift this side of the Keyboard up.
CAUTION!
The Keyboard can only be lifted to no more than a 45 degree angle, then it is slid forward towards the LCD Module.
There are plastic tabs formed out of the frame of the Keyboard, on the bottom side. (Side towards you)
If you lift the Keyboard straight up to a 90 degree angle, you can break the tabs off!
(The Keyboard Cable is under the small metal Keyboard Support Plate. There is a SPECIAL method, to disconnect the Keyboard Cable from the motherboard )
http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-G35/disassemble-laptop-1.htm
Step 6 shows the Keyboard Support Plate (Middle), and the Wireless LAN Module Cover. (Right) Click on the photo to enlarge.
{Wireless LAN Card}
http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-G35/disassemble-laptop-2.htm
Step 10 shows the Wi-Fi (Wireless LAN Module) module, and the Bluetooth module. (BT)
IF, your laptop came with Bluetooth.
WHEN you unplug the two cables from the Wireless LAN Module, be SURE to make notes, and/or marks, on the connections they go to.
Color of the wire, and what terminal it connects to.
Put them back in the same place. Always route the wires back in the SAME channels, and Latches, they were originally.
Failure to do so may pinch a wire, and cause damage. At the very least the laptop will Not go back together.
Two Philips head screws hold the Wireless LAN Module in place.
Do NOT drop them.
The opposite end of the Wireless LAN Module plugs into a connector.
The module is to be removed at NO MORE than a 45 degree angle.
Failure to do so, and lift it straight up, will damage the connector, and the module.
The page numbers are on the Bottom, and Top of the page, in white.
Page1::Page2::Page3::Page4::Find another model
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Feb 18, 2012
Toshiba G35-A600: How to replace the wifi card?
Please follow this link for the schematics:
Click here
Gadget
Feb 21, 2012 | Toshiba Qosmio G35-AV600 Notebook
I bought a toshiba qosmio x775 and it's pretty cool, but i fully charge it and the next day it's battery is like 80% or 75% percent and it's weird and i don't like it, how can i make my...
Toshiba Qosmio has many advantages, eg tv, wifi, and the extra screen width...
Disable some features might reduce the power consumption.
Or you can try free trial BATTERY DOUBLER >
http://www.dachshundsoftware.com/buy.html
akee.4shared.com
Aug 16, 2011 | Toshiba Qosmio G25-AV513 Notebook
Need to clear bios password on qosmio g-35 av600 cannot load recovery disks unless i can enter bios password
Laptops can be quite tricky to clear out. Only thing I can do is tell you to unplug the laptop. Remove the battery. Try to turn it on for about 10 seconds repeatedly ( this drains latent power from the main board) Put the battery back in, plug it in and give it a whirl. Hopefully that will be enough to clear the bios.
Mar 30, 2011 | Toshiba Qosmio G35-AV600 Notebook
My Toshiba satellite laptop constantly cant find networks even though it is within the 50 ft. Radius
From my experience with Toshibas is that the internal wifi cards are cheesy. They don't get the range that say a Dell does. Also WiFi extends 100 yards in a straight line and about 35 feet around the router. You might just have to move closer or get a good USB adapter.
Jun 09, 2010 | Computers & Internet
My video card on a Toshiba Qosmio 35-av650 is fried so I switched to base video. Is the Standby (S3) feature affected by my use of base video--I ask this because now neither Standby nor Hibernate are...
no changing video card does not affect in hibernating or standby. go to control panel and check if your standby and hibernation options are activated and if they are then you should make some space on your c drive because hibernation property requires 1gb of free disk space
Apr 18, 2010 | Toshiba Qosmio G35-AV650 Notebook
Toshiba Qosmio X305-Q705 Laptop screen yellow
It is not a driver or video card problem. It is the monitor.
To be sure plug a full size desktop monitor into your laptops monitor jack. Every laptop has one. If the picture doesn't turn yellow that will confirm that your LCD is bad.
Aug 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
BSOD - NV4_disp.dll - Toshiba Qosmio G10-133
Re-install Windows, at the start ofthe installation, delete the partition, the create a new partition, the do a full NTFS format.
Mar 17, 2009 | Toshiba Qosmio G10-133 Notebook
Open up a toshiba qosmio f25 av205
This site has free info and Pic to open up the laptop.
one screw is hidden under monitor cable.
look up replace video card.
Ckreuzer
Dec 26, 2008 | Toshiba Qosmio F25-AV205 Notebook
VGA card for Qosmio F15
Yeah, laptops don't have a seperate video card like a desktop.But it may not be the vidieo chip.It might just be an inverter problem,which is relatively simple and inexpensive.I can't be sure unless I see it . shops are notorius for trying to sell people new motherboards.Get a second opinion.
Feb 10, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba Qosmio G35-AV600 Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
