Question about Dryers
No power to dryer, checked fuse and power outlet tey are OK?
  • englander Oct 26, 2008
    The brand is Indesit and its a GV74
    the make and model is an Idesit GV74
  • 1,543 Answers
First, use a voltmeter to confirm that you have 240 volts to the outer two terminals where the cord connects onto the dryer, and 120 volts from each of the outer terminals to the center terminal. If that checks out OK, look for a broken belt. (a broken belt opens a switch to prevent the motor from running) If that is OK, look for a safety thermostat, about the size of a dime with two wires on it, usually near the top of the heating element. If no continuity there, replace it and try to improve the vent to prevent future problems with it. Newer dryers have auto reset safety thermos, but older ones didn't and they acted like a fuse and needed to be replaced if they tripped. Next time you post a problem, please list the brand and model number. Thanks.
Posted on Oct 26, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Oct 27, 2008
    Sorry, I'm in the USA and don't have any direct info on Idesit brand so I can't look up part numbers or find diagrams on it, but the info in my solution should still be sound. If you need more assistance, prehaps you will have to try another post listing brand and model so someone in the UK will take a shot at it.
I have an AEG Lavatherm 56840L condenser dryer which has just died.No dispay anything! I have checked the fuse and know the socket is good but beyond this I am lost.Any ideas?
Ok you said you checked the outlet, question is how did you check it. Cause it may show power, but the neutral wire may have the problem. You could have power to the box but without the neutral it will do you no good. Now if you open the panel of your dryer you should find the tech sheet, which will aid you to trouble shooting, in case your outlet is good. Take a lamp and plug it in, see if will light up.
Jun 24, 2015 | AEG Dryers
My dryer quit heating and I replaced thermal fuse. It heats now, but when the door is opened it does not stop running. The switch seems to be OK. Have any suggestions? It did not do this before fuse...
Hello Rohanna
You need to check this following:
Make sure the dryer is plugged in securely
Check for a blown fuse or tripped circuit breaker
Test the power outlet for voltage
Inspect the electrical cord for damage
Eliminate use of an extension cord, if any is being used
Check the outlet voltage
Test the door switch
Test the start switch
Test the safety fuse
Test the thermostats
Test the timer motor
Test the motor
Best Regards
Neciforo Llanto
Oct 01, 2013 | Kenmore Dryers
Dryer has power but will not heat
Remove the back of it and also the top. There is a relay switch that could be bad. If the element is ok, check the relay by bypassing it. If it works, then replace it . Look at the wiring first when you take ff the back. This is common to it, since the fuses are ok. There could be just a wire that is burned and come loose from the connections.b
Feb 04, 2013 | Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
No sound at all
Come on you have to do better than it an electric or gas dryer? The first thing to check is : does it have power? Plugged in, power to the outlet (fuse OK)? No workie if no power..................
Jul 30, 2010 | Dryers
My dryer won't turn on what can i do?
Check house fuses or circuit breaker.
Ck. power cord and power outlet for signs of arching an replace if needed.
Ck. power cord at dryer side and make sure the ends are not burnt. Unplugged of course.
If all is ok call for service.
Jan 16, 2010 | LG DLE2532W Electric Dryer
Dryer will not turn on. Checked outlet with
unplug dryer and take back panel off. plug back in. use caution your working with 220v. get a reading on power cord where it connects to dryer. if your good there look for a micro fuse, two small wires connected to it very small component. sounds like you have a bad power cord or power surge popped micro fuse. good luck and be safe!!
Jan 09, 2010 | Magic Chef CYE3005AYW Electric Dryer
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire terminals.
gas or electric ok gas replace gas coils check glow bar ignighter,check thermostates,,,,,,electric check power to both sides of wall outlet you need 220 volts and it will start and timer will advance on 110 vts second check second fuse looks like a thermostate normally located at top of heater coil call if you need to
Dec 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have no power
Check all your breakers/fuses panel if none are tripped or blown we will assume power is @ the outlet, check it w/ a meter if you have one. I have never seen a reset button on one before but there could be a internal fuse inside the unit, to check for that you will have some disassemble work 1st
Oct 25, 2009 | Dryers
Dryer won't come on. it is plugged in and the outlet and breaker checked out ok.
are you getting voltage when you say you checked outlet? is it a gas or electric dryer? should have 220 or so at dryer for electric and 120 for gas. if voltage ok, trace it through to fuse most likely. no light in dryer means no voltage...
May 24, 2009 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
