Question about Nokia N73 Cellular Phone
How to switch off the light will recording through camera
I just needs to know how to switch-off the camera light will recording in day light. and vice-verca
Regards,
Sharad
  • sharad loves Oct 26, 2008
    Hi again,
    If this is the case then more & more the battery will be used while recording through camera.
    There should be some setting for the same.
    For instance if we use the front camera for recording it doesn't require any light
    Request your proper solution.
    Regards,
    Sharad
Sir as i told you this is the nseries setting you can turn off the camera light while you maaking movei
thanks
your friend from fixya!
Posted on Oct 26, 2008
  • 51 Answers
Hi
sir the camera lights remains on when ever you take movei in day or night it the n73 progaraming
thanks
I have a JVC Everio GZ-MG20. The recording screen shows black - as if the camera lens is on, but it is not. Audio records fine, but there is only black screen for video. Is this a firmware problem or a...
Can you see through the viewfinder while recording?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 04, 2010 | Cameras
Hi, need help with the camera not powering down unless i take the battery out & when i try to record the camera says record but the counter clock is not showing any recording time, any help would be...
Once you turn off the camera and remove the batter, does it power on and if you press the off button does it go off ?
Try this
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Nov 27, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
Jun 14, 2010 | Dome 4 CCD CCTV Camera Surveillance...
Sony handycam says ''reinsert the tape'' doesnt record or replays
Hi, that look like if the cassette in switch is not work
because the camera act like if she dont see the tape
in the cam or that could come from the mode swith in the mecanism ,the mode switch is act to tell to the servo control ic where is the position of the mecanism...that mean could need an aligment
for these type off camera you will need a good tech
hope that help you
have a nice day////AS
Mar 26, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
How to switch off the light will recording the through camera
For this go to camera---> camera settings--->light settings--->make changes as you like.
Thanks
Oct 26, 2008 | Nokia N73 Cellular Phone
Tascam dp02
hi, might need your services in the future so i will save your site cheers . here is the fix which i found on a tascam forum ( press track edit and arrow up) this re instates factory settings . after i did that the (record) light and (play )light worked although there was no sound thru my h/phones when i recorded aaaagggghhhh switched off the unit fed up. the following day when i switched the unit back on every thing was ok .maybe it required to be shut down?? a bit like a pc, for all the corrections to be installed who knows it must be said that i am a technical buffoon i prefer hitting big rocks with big hammers ,this foray into high tech numbs my brain instantly and leaves me with a twitch .william
Jul 20, 2008 | Audio Players & Recorders
Flash and Video Light
i had the same problem if you have the same version as me there is a littel switch on the upper right of your camera switch it so the flower thing is off make sure it is off the charger and make sure the battery is put in correctly those are all the problems i had once i fixed those my flash and light started working
Jan 04, 2008 | Jazz DV165-BOX Digital Camera
Please help me now!!!!!!
hi sir , it seems you have extra light exposure so it hapens from the selection you use on this camera as a LOW LIGHT if you know where to find that selection or knub then try to select normal or refer to AUTO select for the light exposure and white balance that is the only matter to solve the problem please don't forget to rate and remember i am here just for help thx
May 07, 2007 | Sony Handycam DCR-TRV140E Digital...
Sony Cyber-shot DSC-W50 Record Mode
I had the same problem and you go to menu then REC mode and make sure it is on normal, mine was on multi burst and thats why it was recording on every setting. Hope this helps :)
Apr 29, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
