Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
How to hook up hose
I need directions on how and were to connect hose to carpet cleaner to use my spin brush attatchment for upolstry?
reddevil6
  • 1673 Answers
SOURCE: Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 3 Answers
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
Turbine assembly is bad. Get part #23 here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Not to bad to put in.
You can also find them on Ebay cheaper.
Posted on Jul 01, 2008
reddevil6
  • 1673 Answers
SOURCE: I have a hoover steamvac
One cause is that the recovery tank lid isn't on correctly and not sealing. If there is a foam filter on the inside of the lid, make sure it has a 1/4 in. gap from the top of the lid. There is another filter, from the bottom, it has a red frame, pull it out far enough to clean it. May have a bad turbine, or the shaft on the top of the brush block broke off. You have a 1 years warranty on this, I would take it in to a warranty repair shop and get it repaired.
Posted on Aug 10, 2008
  • 240 Answers
SOURCE: i cant get the brushes
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Posted on Jan 28, 2011
My dyson 07 has no suction
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
Aug 06, 2014 | Vacuums
My vac cleaner doesn't pick up.
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Jan 13, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
MY WIFE BOUGHT THIS FOR ME FOR FATHERS DAY GIFT ABOUT ALMOST 2 YEARS NOW OR SO,BUT I HAVE THIS PROBLEM THAT THE BRUSH DOS'NT SPIN ANYMORE EVERYTIME I PUT THE SWITCH ON FOR BRUSH ON,THE HOSES BRUSH SPIN IS...
This unit uses a turbine assy to turn the brushes. The brushes could have something jamming them. Remove the brush unit, it is held on 2 spring hooks 1 on each side. The brush unit is driven thru a 1/4" square post, only one brush is driven and it drives the next then it drives the next etc. If something is jammed in these gears it will stop the entire brush assy. The turbine assy could be bad, but I would check the brush assy first.
Nov 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
MY HOOVER DUAL V STEAM VAC CARPET CLEANER BRUSHES WILL NOT SPIN! WHY?
There are three things to check:
Is the switch on the hood for brush speed set to full, or may it be set to OFF?
Remove the brush block from under the unit by pulling it down and unlatch each side. Is there a 1/4 inch square drive pin on one brush, about two inches long? It connects the brush to the drive mechanism.
Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replaced.
Oct 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Beater brush won't spin but belt is intact and ok. Brush is clean and spins freely by hand.
For your beater brush to spin, you have to meet two conditions:
1) the vacuum cleaner has to be reclined (put your foot on the front and pull back on the handle).
2) The clutch actuator (the dial where you switch between BEAR FLOORS and CARPETS needs to be set to CARPETS).
If the brushbar/beater bar still doesn't spin after that, call the Dyson helpline, they will assist you. If you are saying that the brushbar isn't spinning because it is not picking up any dirt, you may have a loose internal hose, a blockage in the machine or the bristles on the brushbar are worn. Call the Dyson helpline for assistance.
Jul 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Have a Hoover Model F5887-900 upright carpet cleaner. I am having issues with the attatchments. The brushes will not spin on the handheld attatchment and the solution trickles out. Any...
HI ,
I AM BILL AND I HAVE A SIMILAR PROBLEM. I HAVE FOUND THAT THERE IS A SHIFTER VALVE NEAR THE REAR OF THE MOTOR AREA.
IF YOU LAY THE HANDLE DOWN FLAT YOU CAN SEE WHERE THE VACUUM HOSE ATTACHES TO THE SUCTION MOTOR. CHECK THERE TO SEE IF IT HAS COME APART.
NEXT CHECK THE SHIFTER VALVE AND SPRING MOVE ROTATE 1/3 OF A TURN . WHEN YOU LOWER THE HANDLE THE SHIFTER HAS TO BE IN THE FLOOR MODE FOR THE SUCTION TO THE MAIN FLOOR SCRUBBER AND SPIN THE BRUSHES.
TO USE HAND TOOLS THE HANDLE HAS TO RAISE UP AND LOCK TO OPERATE ANY HAND TOOLS.
A PLASTIC LEVER BREAKS BY A SPRING CALLED THE SHIFTING LEVER. A SHIFTER VALVE LEVER IS THE RIGHT REAR, THE HANDLE DOWN. GOOD LUCK
MY PROBLEM ACTUALLY THE SHIFTER DOOR AND I HAVE A LOT OF SEARCHING TO DO TO FIND THAT.
OH! BY THE WAY THE LEVER PART # IS 90001320 $2.16 + SHIPPING AT SEARS PARTS DIRECT
Apr 29, 2009 | Vacuums
Model #5880-900 Hoover spin brush carpet cleaner
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
22 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
