Question about Poulan Garden
Poulan 245a hard to start and keep running.
I have a Poulan 245a chain saw, its a 72 or 74 cc and is very strong motor. However, the engine is hard to start and cuts off after some work about 15 min of work. I cannot find a user guide for it. What could be the problem. I have replaced the carb and put a carb kit on it. I was told to check the exhaust port for blockage. My concern is the points and condenser. It does not have a primer bulb for the carb.
    Master:
  • Poulan Master
  • 607 Answers
You will need to follow the chart attached to determine why the saw is having issues.
Posted on Dec 20, 2017
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan 221 pro 40cc chainsaw that needs a fuel
A typical fuel system and a couple of tips can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Poulan PP221 Gas Chain Saw Type 4 IPL link (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP221-Gas-Chain-Saw-Type-4/75.PP221-Gas-Chain-Saw-Type-4.1.59.1.html
All fuel components are listed.
If not your saw yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you need additional help or have questions please reply below and I will get back to you. HTH
Lou
Posted on Feb 19, 2010
dontbother10
  • 2220 Answers
SOURCE: Primer bulb-carb routing
It should be like this.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 10, 2010
SOURCE: Just replaced fuel lines and
Line from fuel filter goes directly into the inlet of the carburetor and the line from the snap in bulb that is marked "in" attaches to the other outlet connector on the carb. Last is the long side of the bulb goes to the return on the gas tank. The snap in bulb sucks the gas but not directly from the filter hose, it does this through the carb as if it were trying to not only **** in the fuel but also removing the air trapped in the carb. You'll notice that the bulb has a **** side and a discharge side, and the **** side goes directly to the carb outlet connector. I tried to make this a clear as possible, and I hope it helps.
Posted on Oct 17, 2010
SOURCE: my Poulan 3500 chain saw will not start
3500 poulan runs and secand stop
Posted on Oct 22, 2010
I can start my Poulan 2000 16" chain saw but it
If the saw is brand new, take it into a service dealer for a carb adjustment (covered under the warranty). This sounds like it is your issue and unfortunately, you cannot correct it yourself because it requires a special tool.
As for you manual, it is located at the link below http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137248.pdf
Jun 25, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Have 60 lbs compression is this low , poulan chain saw mod p3314
60psi hmmmmm??? it wont even start up on that?? yes it is very low
most engines run on about 120 to 180psi and the 120psi end being low! how did you test this presher??? you need a good true screw in gage and a very strong swing to build the presher up a push in gage is usless and a soft pull wont build the presher up,,,it dont realy matter how big the engine is or how many cc's it is it still needs to get to 120psi to start and run well,,,,me thinks you may need a set of piston rings fitted to this engine just to run it up,
Jun 29, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
May 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
No problem i want to know how big the motor is in cc's
40 CC's or 2.5 Cubic inches
Poulan, Wild Thing, 2375, 18" Gas Chain Saw, 2.5 CUIN, 40CC, 2 Cycle Engine, Vertical Cylinder Design, Dual Counterweight Crankshaft, Primer Bulb, Inertia Chain Brake, SuperClean Air Filtration System, Gear-Driven Automatic Chain Oiler, Full-Wrap Handle
Mar 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan PP4218AUX will not start
I have a 42 cc 14"bar will not start. poulan chain saw.
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Dec 05, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
83 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
