Question about Miele W310 Front Load Washer
Washing machine stops mid-cycle with Rinses light flashing.
Hi, I have a problem with my washer where it stops mid-cycle with the 'Rinses' light flashing. I had a Miele technician come out to look at the problem. When he performed a diagnostic on the machine with his laptop he couldn't reproduce the problem. Admittedly he ran a quick-wash cycle without any clothes in the machine, and this is why it did not re-occur, I'll explain more on that in a bit. His laptop did however manage to find in the washing machines error log that it had encountered a W50 "motor fault", but because it ran through the cycle OK he said that it couldn't be a fault with the motor, more likely a problem with the main circuit/logic board that controls the machine. The only problem I have with this is that a replacement board will cost me $460 plus labour costs. I have subsequently re-run some washing cycles since, and through experimentation have found that the problem seems to only occur when there is certain amount of clothing/material in the machine (nothing over and above what it should, and has been able to wash over the last 7 - 8 years). It seems to me that is "senses" too much load on the motor and this leads to it ending up in this state. I found a suggested fix to a similar reported fault on this forum. They suggested worn motor brushes, but this seems unlikely as the guy from Miele said that they don't wear out through normal use for at least 15 years. Any ideas?.....
  • 14 Answers
SOURCE: Miele Premier novo washing machine
Faulty cold inet valve most likely the problem or cold tap off Good luck
Posted on Sep 14, 2007
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
Nicesuit
  • 61 Answers
SOURCE: W830 washing machine stops before end of cycle.
could be something to do with the drain pump, the machine gives itself 3 mins to get bellow a water level before it spins, if it cant make the water level in 3 mins it stops because the weight of the water and clothes would be too much for the machine that would start to dance the tango, check the pump and sump for minor blockages first.
Posted on Jul 23, 2009
  • 70 Answers
SOURCE: My Miele Novotronic W 844 Washing Machine will not
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Posted on Mar 30, 2010
  • 70 Answers
SOURCE: Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Posted on Jan 30, 2011
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele W310 Front Load Washer Logo
132 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
