Question about Panasonic Viera TH-42PZ80U Plasma TV
Not turning on led blinks twice
Plug unit in and fans turns on but screen doesn't then the red led light goes though a loop of two blinks and pauses then two blinks. Where can I get a diagnostics list for led signals.
  • Panasonic Master
  • 8,617 Answers
If your model is the TH42PZ80U 2 blinks is indicating to replace the D Board (Logic) That model used two different versions D board. www.tvcircuitboards.com has both versions and can assist with determining which version your model uses.
Posted on Feb 18, 2012
2 Suggested Answers
  • 96 Answers
SOURCE: doesn't turn on. LED is blinking twice with pause
Needs to go in for service. no other option.
Posted on Sep 27, 2009
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
Pn43d490 clicks blinks red light twice and will not turn on
do you have a dim screen? if you put a torch to the screen at an angle can you see the picture?if so this means the backlight is out, it could be the inverter board or the bulbs themselves though this is unlikely.do you get the 24Vgoing to the backlight from the psu?
Dec 09, 2013 | Samsung PN43D490 3D Plasma TV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
My sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
Jun 22, 2012 | Sony Televison & Video
Sony nsx-40gt1 doesn't turn on and red light
The 2 blink error for this model is letting you know that you have a standby power voltage problem. 99% of the time it is your power board. If you bought this set with in the last year, you are still covered under warranty. I would call Sony or a Service provider to get your unit fixed at no charge to you.
Apr 18, 2012 | Sony Televison & Video
I have a remote oneforall i need codes for a SHARP VCR please help need codes
There are two codes for Sharp. You'll have to try both to see which one works. 0048 & 0807. I am assuming you don't have a manual.
On the remote press and release the VCR/DVD button. Press and hold the SET button until the LED blinks twice. (it will blink once when you first press it, that doesn't count.) Just wait a few seconds. After it blinks twice, release the SET botton, and enter the CODE..
The LED should blink twice. Aim the remote at your VCR and press
POWER.. The VCR should turn on. If not, try the other code.
0048 worked on mine. Good Luck!
Aug 15, 2011 | Universal Remote Control Remote Control
Need the set up for a samsung tv
These are the setup codes for Samsung 0030, 0060, 0178, 0702, 0812
Manual located at http://www.oneforall.com/uploads/support/8210f6981b8d184d890a27645d6c32df.pdf
PROGRAMMING DEVICE CONTROL:
1. Turn on a desired device
2. On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
May 04, 2011 | One For All URC4220 Remote Control
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
I have a Braemar LCB450-G evaporative cooler. There are two Diagnostic LED,s on the electrinics module,one red & one green. When the power is turned on at the module the red LED remains on & the...
There are several possibilities, the drain valve is opening and closing, this causes water to fill the base, the float valve will not achieve the desired level so the fan will not start. This could be the drain valve actuator is U/S or the PC board. Have you tried to turn the main power off at the switch board for 1/2 hour?
Most occasions the service person will swap out all the units as they purchase it as a package. It is not cheap to replace these units.
Nov 22, 2010 | Heating & Cooling
Panasonic Viera TH-42PZ80U Plasma TV Logo
243 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
