Question about Whirlpool MH1150XM Convection/Microwave Oven
Under Hood Light, bulb is fine (brand new)
When replacing my burnt out bulb, I negliected to unplug the microwave, and alas, blew a fuse in the house's fuse box. I have since replaced the bulb, but the light still doesnt work. I tested to see if electricity is event getting to the bulb outlet, which it is not. Is there an internal fuse box? How do I get to it? I did some slight exploration, but didnt want to dig to far without knowing what I am going after. Thanks, Chris
  • 1 more comment
  • ukusa Dec 05, 2007
    My Sears Advantium 120 hood light bulb and extractor fan is no longer working.  How can I fix this.  Thanks Steve
  • thecurler Jan 21, 2009
    I think the fuse is blown on our kitchenaid over the range microwave. I had the control panel off and can see the fuse but it is wedged right next to the little fan. Any ideas on how to change without pulling everything off?
  • adnil1015 Feb 20, 2010
    Same thing happened to me. Went to change the lightbulb w/o unplugging the unit and the whole thing won't work now. Where is the best place to get a control board?
  • Whirlpool Master
  • 9,156 Answers
This is a problem with the control board, which we commonly repair for $32.50. This is caused by not disconnecting the microwave from the power line when removing or installing a bulb. Feel free to e-mail me at _ for more information or visit _ for full details.
Posted on Sep 15, 2006
  • 32 Answers
There is definitely a fuse in the unit. It normally is behind the control panel. The control panel opens by removing just one or two screws and possibly lifting up slightly to unhook from cabinet -BUT UNPLUG UNIT BEFORE DOING ANYTHING. Do not understand why changing light bulb would blow any fuse - unless you did something unusual.
Posted on Aug 22, 2006
Chris, I just had the same thing happen and am online trying to find a fix. I have taken the whole thing apart looking for a fuse and only found one that appears to be the "main". Did you find the "fix"? Thanks so much! John Birmingham, AL JBLYDA@CHARTER.NET
Posted on Sep 04, 2006
SOURCE:
While changing the light bulb under the unit, the wire connected to the light bulb holder touched the metal housing and totally blew out the microwave so it doesn't work.
normally there is a glass fuse in the circuit where the power comes in
check that fuse/ replace if necessary
As silly as it sounds --turn the equipment of at the wall before you work on it as it might have been you that blew and not the fuse
Jan 16, 2016 | GE Adora DVM1850 Microwave Oven
Lights under microwave will not come on
When this happens, a lot of the time, it is because the the old bulb burnt up violently or it was unscrewed with the power still on to the unit and if the wires on the bottom of the bulb were twisted together, it probably blew a trace off of the back of the circuit board that supplies power to te bulbs. So either need to find someone to repair the circuit board or buy a new one if you can put it in, if not, need to call a servicer to replace it. But caution, thay are not cheap!!! Always unplug you microwave BEFORE replacing the bulbs!!!!!
Oct 14, 2017 | Frigidaire FMT148GP Microwave Oven
THE STOVE TOP LIGHT ONDER THE MICROWAVE BLEW OUT. WHEN I REPLACED THE BULB BOTH LIGHTS NO NOT WORK.
Sounds like a power source issue from under the hood.
Unplug or turn off all power and take a closer look in there,. alternatively - this may sound crazy, but are you certain both bulbs are working by testing in another fixture??
Jan 05, 2011 | Sharp R-1480 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Kenmore microwave model 721.62644200
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 16, 2008 | Microwave Ovens
Magic Chef mco153ubf
I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem.
Nov 19, 2007 | Magic Chef CMV1000B Microwave Oven
Light socket is dead on my Maytag
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 01, 2007 | Maytag MMV4205 Microwave Oven
GE JVM1651 Microwave
The control circuit board needs to be removed and repaired. We routinely repair these from customers nationwide for $32.50. It sure beats the cost of a new board!
Sep 11, 2006 | GE JVM1651 Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
1,002 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
