Question about Car Audio & Video
JL Audio w3v3 frozen
I have 2 JL Audio 10"w3v3-2 subwoofers and out of nowhere 2 of them have frozen up. One wont move at all and the other will only Push out and not in...... Pleasseeeeee Someone help me out.
SOURCE: JL 12W2 Subwoofer
Happened to me, i also had a metallic/iron smell coming from my sub... i pronounced it dead. had to buy a new one and it worked fine... if you believe its not dead then your amp is not getting enough power and most likely shutting off (protection mode), you can try buying a cap, farad 2 or better will work and is suggested for larger subs anyways
Posted on Jan 14, 2009
  • 72 Answers
SOURCE: I have a JL Audio 12 ich subwoofer rated at 8 ohms. also a mono block insignea amplifier at one ohm stable 1-4 ohms. how to i wire it safley? possible?"
Your amp based on what you say would have no problems whatsoever with an 8 ohm load, not even if it actually has dual 4 ohm coils and you wire them in parallel giving a 2 ohm load (don't know your particular sub).
Every good car amp has protection circuits to prevent itself or the speakers from damage from too low loads so it shouldn't be a problem even if you screw up with your calculations. A good amp should even be capable of dealing with a dead short on a channel, zero ohms, activating protection of course.
Good luck and don't worry!
Posted on May 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: jl audio w7 13 subwoofer system 3ohm driver bridge it 2 ch amp
How much is your speaker max wattage?
If it is 750 or below, it can only be used on one channel, either the right or the left.
If speaker can handle 1500 watts then hook the positive speaker wire to R+
Hook black negative speaker wire to L-
Now it is bridged
Posted on Aug 19, 2009
  • 12 Answers
SOURCE: i want to know the best subwoofer wiring diagram
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Posted on Nov 30, 2009
Professor_V
  • 92 Answers
SOURCE: how to wire a JL audio 12W3v2-d2 subwoofer . there
http://mobile.jlaudio.com/support_pages.php?page_id=161
THE ABOVE LINK WILL TAKE YOU TO THE CORRECT PAGE ON THE JL AUDIO WEBSITE THAT PROVIDES A NICE TUTORIAL ON CONNECTING YOUR SUBS. THIS IS FOR THE DUA VOICE COIL SUBS. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 14, 2010
I have an Alpine PDX-5 amplifier powering my door speakers and my JL 10 w3v3-2 ohm subwoofer. The door speakers are still working, but the subwoofer has stopped working. Every once in a while it will...
check the power and ground and also the turn on lead that goes to your radio for a loose connection if thats not it then your amp may not be working or the subs
Nov 28, 2010 | Jl Audio 10W3V3-2 Car Subwoofer
How do i fix my blown jl 10"w7?
pay to have it shiped to jl call 954-443-1100 and they can help with this problem and give you the price quote
Sep 01, 2010 | Jl Audio 12W7 Car Subwoofer
I am wondering what amp i would need for 2 JL Audio W3v3 - 2ohms. I am looking for something around 200. SHould I go with the Mono block and how many watts?
well you can go a couple different directions. you can wire them parallel or in series. parallel will get you down to about 1.3 ohms at the amp and series will get you close to 4 ohms. you need an amplifier thats stable at either of those impedances. the lower the resistance (impedance) the more power your going to get to the subs. I manage an electronics store and specialize in mobile audio/video. we are a 'Signature JL Audio Dealer' so i like to say i know the product line very well. JL makes an amplifier that is stable from 1.5 to 4 ohms and will put out the same amount of power at any impedance in that range which is really nice. Its called their 'Slash Series' you are looking for a JL Audio 500/1 amplifier. Grab an 8 gauge amp kit (4 gauge would over do it) and wire 'em up. Enjoy!
Mar 17, 2010 | Jl Audio 10W3v2 Car Subwoofer
I have two jl audio 12 w6v2 running with a jl audio 1000/1 and at high volume they make a poping noise does any one know y
That popping noise is your speaker telling you to turn it down, and that your amp is too powerful for your setup. The speaker cone is moving beyond its limits of excursion and on it's way to malfunction/blown. Basically the voice coil will fry.
Mar 16, 2010 | Jl Audio 12W7 Car Subwoofer
Which amp goes with 2 jl audio w3v3 4 ohm
Choosing a amp isn't always easy but it first begins with what you want.
--RMS of the speakers is what you want to use to find your amp.
That's going to tell you what watt's your speakers can REALLY handle @ 4 ohms.
--Also what you want to spend $$$ will determine how clear it sounds.
--I prefer a Rockford Fosgate amp for base and kenwood for highs.
--Also look at the RMS watt's rating to find the proper power and go a bit beyond what you want so that the amp performs with ease.
--Last but not least you chose the amp for how many speakers you are going to connect to that amp. For example if you are using 2 JL audio 12" for subs, then a mono amp is perfect. But if you are connecting 4 speakers, you should begin to find the amp with four channels so that you obtain left, right , front and rear sound.
Mar 16, 2010 | Jl Audio Car Audio & Video
Popping sound! please help - jl 500/1 and two jl w3v3 2ohm subs
no connection are good + to + -to - thats all that matters. either the speakers are blown or you need a stronger amp. since you already tried speakers probably need bigger amp. definitley not the box. no such thing as a break in period, are the subs 10 12 inch or what. you could try to bridge them too that means hook both up to the same +-terminals, 2 wires per screw. it usually isnt the way they hook them up, its the wires fuses etc that cause problems. what guage wires is the speaker wire, the power line etc. if you give me these guages i might be able to get somewere
Feb 24, 2009 | Jl Audio 12W3 Car Subwoofer
The magnet on my JL W7-3 came off. I dont know how it happened. I tried to put it back on an now it wont move. Can ne one help me out? Please.
the coil of wire inside the speaker has seazed up, u can either replace the speaker or send it off to be re-wired.
pleasr rate this advice.
Feb 22, 2009 | Jl Audio CLS113RG-W7 Car Subwoofer
Surround seperated from subwoofer
You can order repair kit here:
http://www.simplyspeakers.com/2doityourself.htm
Aug 02, 2008 | Jl Audio 12W3 Car Subwoofer
JL Audio discontinued 12W6
YOU JUST NEED TO REPLACE THE VOICE COILS TRY EBAY THEY DONT HAVE TO BE FROM JL AUDIO.
Jun 01, 2008 | Acoustic Research AR3 Speaker
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
