I can't figure out how to disassemble a SimpleTech prodrive casing. This is the model with two tone casing and two of the corners rounded off diagonally. I've located the three (hidden) screws, and I've been assured that it's a simple case to slide off one of the sides. I feel like this is an intelligence test and I've failed it, but no amount of sliding or prying does anything. Please help.
  • 226 Answers
One of the sides is not really fixed in it's position after you take out the screws, you could say it rattles. That's the side that slides out. try insisting. It will come out.
Posted on Feb 29, 2012
How to put songs on The Simpletech Drive?
Just plug the Simpletech in the old computer that has the songs on it. Your computer will recognize the Simpletech drive. You can copy (from your old computer) and paste your songs to the Simpletech drive. Maybe all the songs you want will be in your My Music folder under My Documents. If so, you can just copy the whole My Music folder to the Simpletech.
Once you have the songs on the Simpletech, you can now plug it into the new computer. You can copy an paste from the Simpletech to your My Music Folder on the new computer.
You can also use the drag and drop instead of copy and paste.
May 23, 2012 | SimpleTech SimpleDrive 160 GB External USB...
How do i open my 160 simpletech on my pc
See the FAQ's on the Hitachi SimpleTech support web site which may help answer your question, assuming you mean to open a view of the contents of the drive rather than open the casing.
Jan 14, 2012 | Computers & Internet
Power supply
I THINK THERE IS NO POWER ADAPTER COMES WITH THIS DIVICE IT ACTUALLY PULLS IN POWER FROM USB U JUST NEED TO FIND THE POWEWR CABLE FROM THE USB .
Dec 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Have several Simpletech 250 GB drives. All are consistently recognized by my Lenovo laptop but one. That one problem drive will rarely get recognized about 1 in 200 tries on my Lenovo laptop. The problem...
Hi
You don't say how all these devices are connected at any one moment in time, whether you use a USB hub to plug multiple devices in simultaneously or whether your otherwise detailed and very good description of the background to the fault applies even when nothing else but the problematic drive is plugged into the laptop, or whether you use the same or different USB cables with the different drives and the different computers. It's worth eliminating a USB Port fault or a USB Hub overload or a USB cable fault as the potential causes of the problem, if you have not already done so.
USB is a relatively limited technology in Data Transfer Speed terms and is susceptible to Data bottleneck problems leading to read/write errors in external drives.
The Simple Tech case contains a controller card. The Simple Tech controller card may be faulty or failing due to an accumulation of such read/write errors and is probably not communicating well with the Lenovo's Operating System. Because of Temporary Files and Error Reports created whenever a read/write errors occur, The Lenovo 'remembers' the problematic drives electronic signature from the last connection and also remembers its response and therefore defaults back to the same reaction most times you connect the drive in question. The drive has no 'history' with the Dell, so no problems arise when it's connected there. The other drives might be mechanically identical, but the internal controller board of each has a different electronic signature.
The controller card has a chip on it that contains information in it that identifies what type of device it is to your operating system and then invites the Drivers for the device to start intermediating between the device and the operating system. Some error in the interface between that chip and the Lenovo is causing your problem.
It is purposeless to continue using the problematic SimpleTech Enclosure with your Lenovo Laptop. You have already alighted on the best, simplest and most practical solution -re-house the problematic drive in a good quality, well ventilated new enclosure. The controller in the Eagle case also has no 'history' with the Lenovo, hence the clean response.
For intellectual curiosity, you could swap the hard drives around in two of the Simple Tech cases to see what happens.
Also there might be a Firmware update for the problematic SimpleTech Case that might flash and overwrite the Controller card main chip. I am unable to check this for you as I would need the Drive's part Number. This is the relevant site:
http://www.hitachigst.com/support/index-files/simpletech-legacy-downloads
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most insightful, comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 06, 2011 | SimpleTech SimpleDrive 250 GB External USB...
How do I change the message tone on my eternity 2?
Menu
Setting
s
Sound Profile
Normal
[Go to the top right corner and hit the arrow, switch to message]
Message Alert Tone
[see if you like there personal one's, if not.. choose one you have put onto your phone by hitting the "Tones" button in the lower right corner]
Choose a tone
Add
And then SAVE!
Hope this helps!
Sep 06, 2011 | Samsung Cell Phones
I've met space limit for my SimpleTech external drive even though my internal drive still has space and both are 250 GB. Are there SimpleTech programs taking up space and if so how much of that 250 GB...
Your internal drive is different than your external drive. If you put more files onto your SimpleTech drive, then that one is going to fill up faster. The best thing to do would be to go through your SimpleTech drive and delete anything that you don't need. I don't remember my SimpleTech drive coming with any software on the drive, but if it did, it didn't take up much space.
Aug 21, 2011 | SimpleTech Signature Mini 250GB External...
I plugged the wrong power supply (my laptop) into my Simpletech drive and couldn't figure out why just the power indicator flashed but nothing else happened. When I plugged in the right power supply...
It is worth a try. The circuit board of the SATA to USB interface inside the drive casing is definitely fried, but the drive itself could still be alive & usable.
Jul 12, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My Toshiba L305-S5875 Laptop seems to be overheating, especially when I'm watching videos. I'm sure that I just need to clean it out, but I can't figure out how to open the case. I removed...
http://www.irisvista.com/tech/
or this might be yours or close enough to help you get inside it, there will be a pound of stuff stuck in between the heatsink and the fan.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
Jun 10, 2011 | Toshiba Satellite Pro L300 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
