Question about Briggs & Stratton Garden
Excess pressure crank case
Oil pressure builds in the crank case
  • Briggs & Str... Master
  • 2,239 Answers
Either the crankcase breather is blocked or the engine is badly worn, make sure the engine is not over filled with oil.
Posted on Feb 18, 2012
THE OIL ALWAYS PUSHES OUT THE ENGINE AND EXHAUST ON MY HYUNDAI H100 .WHY?
Because the crank case is building up pressure and blowing
your oil out, have your crank case pcv valve checked.
Ray C
Mar 03, 2015 | Hyundai Cars & Trucks
Tecumseh manuals free
mmm interesting.after comming up to temperature engine experiences excess blow by into crank case .doutfull if it has the wrong size rings for the cylinder as there would be other syptoms as well.think some thing is going on with the reed vave sticking open causing pressure build up into crank case
Jun 29, 2014 | Garden
Why does oil pressure build up in oil reservior
Check for a pinched/blocked vent line.
Possible bad piston rings and over pressurizing the crank case (compression blow-by).
Overfilling the oil tank. Check with engine hot.
Also, it could be just a aged/dried up/ cracked o-ring.
May 07, 2014 | Harley Davidson XLH Sportster 883...
Can a blocked pcv cause a oil leak
The upper part of your engine is like a compressor. The lower part is similar, but not to the same degree because there is a lot of room in the lower part of the engine which keep the pressures much lower. Yes, a blocked PCV valve can cause excessive crankcase pressures to build up which can cause oil to leak out of oil seals which are worn and weak. In some cases it can even cause oil leaks on low mileage engines which have no means of venting the crank case pressures. I hope this has helped you. Usually I don't run into too many stopped up PCV valves, just restricted ones and ones which won't close when they are suppose to.Good luck
Apr 27, 2014 | 2001 Nissan Pathfinder
Excess presure in milk crank case on street glide
What year????? Sounds like a breather problem. Does the bike get fully warmed up a lot of a lot of short rides???? It appears to have moisture/water in the oil. Should not have pressure in the crankcase.
Apr 18, 2014 | Harley Davidson FLHX Street Glide...
Engine pressure
Well change the PCV valves they most of the time in the valve covers. If they are clogged up yes pressure will build up in the crank case.
Feb 18, 2014 | Cars & Trucks
Exaust blowing out oil dip stick
Too much crank case pressure, Cause:- blocked crank case breather, worn piston rings gases passing into engine causing excessive pressure. Remedies:- engine rebuild/ replace unit
Dec 27, 2013 | 1998 Mercury Mountaineer
I have a 1995 susuki rf 900 oil is coming out my motor into the breather box
how much oil , have you checked oil level correct , if you run the engine is there a lot of air pressure blowing out of the breather pipe and if so then you got crank case pressure build up and got a problem with rings or valve stems or seals etc ! check compressions too ! P..
Dec 25, 2013 | Motorcycles
Building up pressure in oil pan
check if it has a PCV VALVE OR BREATHER . EITHER WAY IT APPEARS TO HAVE BLOCKAGE . EVENTUALLY THUS WILL DAMAGE THE CRANKSHAFT SEALS AND CAUSE OIL LEAKS .
Oct 28, 2013 | Garden
Engine pressure building up and blowing out cam gasket
CHECK YOUR CRANK CASE VENT AND MAKE SURE YOU DO NOT HAVE TOO MUCH OIL IN IT
Apr 18, 2013 | 1989 Yamaha FZR 1000
Garden Logo
522 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
